MaVRoCK Offline OP
Hey guys,
I've installed a set of Pioneer 6x8s in my front doors and I keep losing the connection to them when the windows go all the way down. I've gone as far as using electrical tape to tape down the excess wire to the speaker magnet...that worked for 2 days, now it's down again after I put my window down all the way in the drive-thru.
Anyone gotten around this??
-Brian
99 Black SE Sport ATX
Running on E1 SVT rims with Dunlop rubber
Pioneer DEH-P3100 CD receiver (2 channels of the amp blown, officially declared dead)
Pioneer DEH-P440 CD receiver
Pioneer TS-6865 6x8's in the front
Pioneer TS-6867 6x8's in the rear
Pioneer TS-WX121 Sub with a Pioneer GM352 amp feeding it
9
9
Haven't encountered the problem myself but it may be due to the mounting depth of the speakers, stock is 2 3/4" for front and 2 1/2" for rears. Do you happen to know what the depth is for your speakers? You may want to check into that.
Quality is remembered long after cost is forgotten.
...Oh sorry I guess I am just another stupid kid who doesn't know anything...
MaVRoCK Offline OP
I don't know the mounting depth of the speakers offhand, but I'll be sure to check into that, thanks.
I have Pioneer 6x8s TS-A6857 in my front. I don't have any problem with them and they sound great. Maybe just too much wire got put in, try duct tape or some high quality glue,,, last resort.. snip some of the wire.
"Wow, that sank fast." "Yeah, like a rock."
96 Contour GL ATX
9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned
Sony CD player: 50wattsx4;remote;
Speakers=50 watt Pioneer 6x8s
Ross Evans smile
man, i had the same problem....i almost stripped out all the screws on my door i re-connected the wire so many times. i endedup wrapping the wire around the hole for the speaker and then taping it down....with a little luck its worked so far.
97 Contour GL
Zetec + ATX
Mesh Grilles
Super-White Headlights
Super-White Foglights
Super-White Washer-Lights
CTA Intake
Removed Exhaust Resonator
DTM Tenzo Muffler
Removed Intake Resonator
No More Badges
Clarion AudioPro Headunit
4 Pioneer 6 x 8
Soon:
Touring Wing
Rims
i had the same problem, same speakers. a few twist ties to bunch up the wires and shorten them enough to stay out of the way will do fine. ive had half a year since i did it with no problems
97 Contour GL
Zetec + ATX
Mesh Grilles
CTA Intake
DTM Tenzo Muffler
No More Badges
4 Pioneer 6 x 8
Soon:
Touring Wing
Rims
Just wondering here, did you guys make sure to run the wire around the window tracks, it sounds like you may have run them on the inside of the track, and when the window rolls down it catches the wire. You have to make a sharp corner with the wire immediately after getting it through the door and run it on the inside of the door panel.
Moderated by  dnewma04_dup1
