I
I
Took my car into the dealership due to the check engine light being on(been on for a while) and an intermittent oil light coming on
Apparently, I have multiple engine error codes: O2 Sensor, EGR, Misfire
They want to replace the O2 sensor
Replace the upper and lower intake gaskets
new plugs and wires
new fuel filter
perform fuel injector service.
$1300
Does this sound like an appropriate cost for this service?
And yes, I took my car to a local mechanic instead of a dealer and he said that I would have to drop the engine to change the oil pressure sender. I lost all faith in his ability/integrity and took my car to a dealer to get a proper diagnosis...
I picked up my car from the dealer. Here is a more detailed diagnosis:
error codes:
P0155 - Heated O2 Sensor Heater Circuit Malfunction (Bank 2, Sensor 1)
P0303 - Cylinder #3 Misfire Detected
P0401 - EGR Flow Insufficient Detected
One of the intake gaskets is leaking and needs to be replaced. you have to replace both if you do one. This leak is causing the engine to run rich/lean/rich/lean/rich/lean. This may have caused the other problems. A new O2 sensor, plugs, wires and fuel injector service are needed. The oil light problem is caused by a faulty switch.
I then brought my car to Autozone and it only showed 2 codes:
I am thinking of finding a local (cheaper) mechanic to replace the O2 sensor, plugs wires and oil sensor and see how it goes. I bought some fuel injector cleaner for $3...
=========== 1998 Black SVT KKM Tru-Rev Intake / KVR Brakes / Knauberized
all that can be done yourself for less than 200 bucks
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
I agree with gearhead. The upper/lower intake gaskets can seem like a real pain but is in fact pretty easy. can be done with just a cuople sockets and a fuel line disonnecter. you can do the egr while your doing that along with the pllugs and wires, also the o2 sensor isn't hard, neither is the fuel filter. If you have a mild sense of mechanics i'd say save $1000 and do it yourself.
1998 T-Red SVT (SOLD) #4230 BOD-12/5/97 99 3L and stuff 2003 Jaguar X-Type
I also agree. If you got some good tools, someone to help you (just becuase, makes things easier) and weekend, take care of it all yourself. Make sure you line up everything you need (all gaskets, parts, and such) before you start to tear down the engine. Read the how-to in the how-to section for rebuilding the UIM/LIM
2006 Pontiac G6 3900SFI GTP Coupe CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint Former Owner- 2000 "Stryped" CSVT CEG Dragon Run- Oct 13-15
You dont even need to disconnect the fuel line. Just lay the rail off to the side in the engine bay on a rag.
2001 BMW 325i Sport, Stickshift '96 Mercury Mystique V6 *TOTALLED* For sale: Alpine CDA-9811 Eclipse Amplifier Pioneer Tweeters
If you were running rich\lean I would expect to see those codes as well P0171\P0174 I think. The lack of these codes leads me to believe that the gasket leak is a bunch of BS.
99 CSVT Green/Tan # 84 of 2760 Built on Wednesday, September 30, 1998 15.376 @ 92.00 MPH Stock 75,000Km 96 Contour GL 2.5L V6 ATX 170,000Km
I
I
thanks guys
H
H
I would have a shop do the fuel injector service. They atually tap into your fuel line and the car runs for a while this cleaner is being pumped through the injectors.
I had that done my throttle response was better, I noticed my gas mileage went up and the car idled a but nicer.
Todras, check ^^^^^^^^^^^^^^^the above post^^^^^^^^^^^^^ out
I
I
Got my car back yesterday. $600 got me new plugs, wires, fuel filter, oil sender switch, O2 sensors. Yes, I know I could do it for 1/3 that myself, but I don't have a driveway or time on the weekends to play with my car...
I started the car and the check engine light was still on... I figured the computer needed resetting, so I pulled the fuse and all was well - for about 5 miles. The check engine light returned and the oil light problem is still there.
Oil Light problem details: As the engine warms up, the light comes on. If I go past 1500 rpm it goes off. As I drive, the rpm threshold keeps rising until the light stays on. At the end of my commute when I get off the highway, the threshold drops again. very weird phenomenom...
The mechanic called to see fi I was happy and I told him no. He is going to run a full diagnostic when I bring my car back to him. At some level, this is generous of him as I brought my car in and told them what to do with it rather than him diagnosing the problem and recommending a solution that didn't work. Nevertheless, for $600, I am going to get my money's worth.
Any thoughts on the root causes of my problems without further info?
