Posts: 102 |
Originally posted by Ronan: Not dissing the Cobra (want one,want one) but you've just highlighted that is has 2 extra cylinders and a blower! and its only 1 second quickler down the 1/4! It just hammers home the achievement of Demons car! That just puts it all in perspective! Congrads again Demon, you must have created a monster.
Well mmars just needs to learn how to drive his Cobra I ran a 04 Cobra with less mods than him last time out at the track. This guy busted a severely traction limited 12.4@119mph with a 2.2 60'. This was going into a full on 20mph headwind which was sucking out about .2 ET and 3mph in trap. I watched another 03 Cobra roll up to the line and make an amazing pass of ~11.3@125mph. What was different in this 03 Cobra? It had an aftermarket SC, full exhaust, LIVE axle rear, 26" slicks. On the outside the car looked stock except for the drag wheels, front and rear.
I know Demon's car is fast as balls, but the difference between a high 13 at 101mph vs a car pulling traction limited mid 12s@119mph is not even funny. I was side by side with the 04 Cobra till about the 660' because he was all over the place. Once he hooked up, it was like I was standing still.
Dave
black 96 Maxima SE
Best ET/MPH: 14.31@99.3mph with a 2.18 60'
JDM intake manifold, ECU, intake, y-pipe, muffler
Posts: 102 |
Can you guys elaborate on the intake manifold work you guys are doing? I know Demon removed his butterfly valves to somehow gain topend performance. The intake manifold setup I have on my Maxima utilizes the same kind of intake runner tuning with butterfly valves. I actually have a manual override switch to make the valves open at any rpm I want. I've noticed that switching the valves on any earlier that 5000rpms results in a pretty severe loss of lowend power. Take a look at my dyno when I flipped the switch at 4500rpms vs 5100rpms.
Why does the lack of the butterfly valves help the CSVT? Is there a loss of power below 4000rpms, but a gain above because the valves and rod are removed to reduce high rpm power?
Dave
black 96 Maxima SE
Posts: 1,087 |
Originally posted by livinsvt: Originally posted by Ronan: Not dissing the Cobra (want one,want one) but you've just highlighted that is has 2 extra cylinders and a blower! and its only 1 second quickler down the 1/4! It just hammers home the achievement of Demons car! That just puts it all in perspective! Congrads again Demon, you must have created a monster. Now please go get that sucka dyno'd?
But the Cobra is stock(I'm guessing) with warranty.
Nope, look at his sig. It's modded! Geez ur slow mmars J/K.
Matt
2002 Subaru Impreza WRX (WRB Stage 4+)
Old Rides:
1999 Sil-Fro SVT Contour 3.0L with goodies (Totalled 6/21/06)
1988 Bronco II (Sold)
You know you launch hard when you beat oncoming traffic through their own crosswalk lines.
Posts: 21,197 |
Originally posted by Dave B: Can you guys elaborate on the intake manifold work you guys are doing? I know Demon removed his butterfly valves to somehow gain topend performance. The intake manifold setup I have on my Maxima utilizes the same kind of intake runner tuning with butterfly valves. I actually have a manual override switch to make the valves open at any rpm I want. I've noticed that switching the valves on any earlier that 5000rpms results in a pretty severe loss of lowend power. Take a look at my dyno when I flipped the switch at 4500rpms vs 5100rpms.
Well the 3L with oval port heads that he's sporting now doesn't have secondaries from the factory. It doesn't need them because of more displacement and tq. A few people have removed them from their 2.5. Makes them a total dog below 3800 though. Their argument is that they never drive down there anyway. They were engineered for a reason. To increase low end.
Yes.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 9,602 |
I found without the secondaries the 2.5L took a very noticeable hit below 2500rpm. (I.E. tractor range  ) 2500-3000rpm was a little weaker but nothing overly noticeable or unliveable. Above 3000 rpm there was no loss. Couldn't tell you what it gave on the top end but I would not be surprised if it was 5 FWHP or maybe more from 4000 to redline. (UIM, intake, heads, etc all play a part too) Heck even if it was miniscule I don't have to worry about the POS IMRC fluttering or it closing every time you leave WOT.  That is all once you have the spark advance tuned in properly (KEY WORDS!!!) Also you have to realize the my UIM is EH'd to the limit. That itself makes a change in the rpm range of the runners since it's altering their max flow ability and low speed velocity. I strongly believe that mod alone allows for a much better power curve above 4000rpm. Especially with the larger 3L engine. Yes the true duals with balance pipe are wonderful for fat midrange TQ and great top end HP but if the engine can't suck the air in to begin with you are not getting full benefit from all of your other mods. I think I am now finally reaping the full benefits of the EHing. Though my plans were always to build a 3L so all my mods were done with that and other future projects in mind
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 9,602 |
Originally posted by incubusjunkie614: now imagine how quick you would be if you were supercharged....*hint**hint*
Sorry to burst your bubble but this project was designed "Specifically" to be the antithesis of the Vortec S/C.
Why is that you ask???
Because I did an entire car upgrade for just the cost of the S/C alone!!!
$1200 Engine (near bullet proof - bullet proof with a accusump!) $1350 MTX (bullet proof) $650 Bilstein struts & springs
$3200 total spent for a car that will likely hand any S/C beast it's ass on the track. (Okay so I had some mods to start with but so do most cars when they get a S/C ) Definitely on a road course since the midrange power of the 3L kills any S/C car. Throw in the fact I did LSD, flywheel, struts & springs among other things for the same cost it would not even be close! Hell my 2.5L was fast on bald stock tires even! Just ask the guys I beat by over 5 seconds a lap.
2000 SVT #674
Posts: 4,970 |
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 1,475 |
Man it really pays to do all the work yourself!!!  I would've guessed you spent twice as much on all the mods youve done to your car
Posts: 9,602 |
Originally posted by bnoon: What kind of rubber are you running now? Stickier tires make all of the difference...
225/50 G-Force KDW
They give good grip for a street tire actually.
I have a set of 225/50 Nittos on a set of E0 rims sitting on a shelf in my garage. As hind sight normally is I now wish I had tried them for my first time out. It's quite possible I could have hit the fastest Contour time ever much less best NA time. The street tires planted 2.2's like it was nothing thanks to all the TQ but those are 2.2's coming from horrible wheel hop and wheel spin. Now "I doubt the platform would have handled it" but if I had a little more traction sub 2 60' times were there for the taking.
It's bad when your best launch (2.17) comes from walking the car out at idle then shifting to 2nd. The 330' time slowed in comparisson though.
2000 SVT #674
Posts: 1,099 |
I actually haven't ran my car since I added the x-pipe, chip, pulley, etc. 12s was running stock.
--Matt
2003 Sonic Blue SVT Cobra Coupe
2003 RedFire SVT Cobra Convertable
2005 Dark Toreador Red F150 XLT 4x4
2000 Black SVT Contour - Beater
