Posts: 89 |
I would like to know your opinions on the best component sets. I am going to purchase some soon. I am currently leaning towards MB Quarts or Focals, as these are availible pretty cheap on Ebay.
1998 Silver Frost SVT Purchased 01/10/02 Mods so far: -Fidanza aluminum flywheel -Clutch upgrade -Clarion ProAudio system, DSP, 13 Band EQ
Future mods: -Intake upgrade -Performance plug wires -Autolite double platinums -Konig 18 X 7.5 Toxxin's -Koni's and Eibach coil overs -Rockford amps, 3 12" Rockford subs, etc.. (Just needs to be installed)
Posts: 8,142 |
How much do you want to spend?
Posts: 89 |
I'd like to stay under $400.
Posts: 8,142 |
The CDT classic line is very nice, and right now, you can get a free set of CDT coaxials with the purchase of the 6.5" components at www.sounddomain.com. They may be worth a look.
Posts: 89 |
Wrong link? Thanx for the info..
Posts: 8,142 |
Posts: 1,083 |
These Crystal Mobile come in under your $400 and sound very nice. I have them installed in my car. Last years model are only $119 from Sounddomain . Great Buy!! Otherwise if you want to make your own I would go this route. Some custom fab will be need but well worth the very little trouble! Digital Designs W6.5 VIFA XT25TG30 DDXO-HP crossover
1998 SE ATX Dual exhaust Body conversion Nakamichi CD-40z HU Sound by Crystal Mobile Powered by a/d/s M860 AMP My Ride
Posts: 89 |
I found an MB Quart 3 way setup on Ebay in my range. Set includes a 8", 5", and 1". Would it be possible to squeeze the 8" and 5" in the door without modding the exterior of the door panel. I know I would have to cut some of the plastic away behind the existing speaker grill. Has anyone already done this? I would like to keep the stock appearance, as I live in a area prone to car theft and my cars appearance makes it enough of a target. Thus I don't want any audio equipment to be seen.
Posts: 8,142 |
Originally posted by Ripster14: I found an MB Quart 3 way setup on Ebay in my range. Set includes a 8", 5", and 1". Would it be possible to squeeze the 8" and 5" in the door without modding the exterior of the door panel. I know I would have to cut some of the plastic away behind the existing speaker grill. Has anyone already done this? I would like to keep the stock appearance, as I live in a area prone to car theft and my cars appearance makes it enough of a target. Thus I don't want any audio equipment to be seen. You could fit the 8, but the 5" wouldn't have a place to go. MB Quart used to have some 8" coaxes that were quite good that you might want to try to find.
Posts: 89 |
Maybe mount the 5" in the door and the 8" in a kick panel with tweeter mounted on the side mirror vent cover, or maybe 8" and 5" reversed. Would this greatly affect imagining? Thanx for your input. You guys are a great help!
