Posts: 1,184 |
I'm looking at buying 2-12.5 Pro Boston Acoustic Subs
Now the hard part, I need to find an amp, My freinds brought up names such as Legacy, Crunch, and Pyle (I know off brand)
I would like a amp at a resonable price (won't break pocket book)but reliable with good sound
I'm planning on running approx. 500 watts RMS to each sub
1996 Mercury Mystique stock (so far)
The leading cause of Atheism in the world are Christians, who accept Jesus with their mouth but walk out the door and deny him by their actions. (*DC Talks greatest hits. track 15)
Posts: 8,142 |
I'm planning on running approx. 500 watts RMS to each sub JBL BP1200.1 http://www.broadwaycomputer.com/shop/Product.asp?ProductCode=2002700
Posts: 491 |
Get a Soundtream Reference1000 if you can find it. Should run about $400-$500. 1000Wx1 at 2 Ohms in "High Current" mode. Pure and clean power. It's a bit older, but late 90's Soundstream equipment is still some of the best stuff out there.
1997 GL Sport MTX, Soon to be the fastest proven Zetec around.
Posts: 8,142 |
Originally posted by Sleeper: Get a Soundtream Reference1000 if you can find it. Should run about $400-$500. 1000Wx1 at 2 Ohms in "High Current" mode. Pure and clean power. It's a bit older, but late 90's Soundstream equipment is still some of the best stuff out there. The reference series had some issues with power supplies. When they worked they were among the best around, though.
Posts: 442 |
Or a Soundstream Class A 10.2 Amp. That is what replaced the Reference 1000, if I am correct.
1999 Silver Frost SVT #2412 of 2760 DOB - 7/30/99
MODS:
BAT Inlet Pipe /w Monster Flow Filter, Rear Strut Brace, H&R Sport Springs, Koni Sport Struts, Panasonic CPQ-DF800u, Baer Brake Kit, Brembo Slotted/Crossdrilled rotors for rear brakes, rear KVR Pads, ASA JS6 17" w/ S-02 Pole Position, B&M Shifter, 22mm Rear Sway bar, Bassani Exhaust. SoundStream Rubicon 604 Amp, 2 SoundStream Class A 5.2 Amps, 2 SoundStream SPL 12" Subs, SoundStream SVX2 Crossover, Rockford Fosgate Capacitor.
Posts: 491 |
I heard rumors of a few bad ones here and there, but never actually saw one. Never had a problem with mine, and neither did any of my friends. I believe the Class A 10.2 Amp isn't quite as powerful, but has a better S/N ratio. But I could be mistaken.
Posts: 142 |
i use a Legacy amp in my bronco and it works fine. They are nice and cheap, too. It would be only around $100 for it.
-1988 Bronco II: Blue and silver with 8 shades of rust. The system costs more than the vehicle  -1999 SVT Contour: Silver Frost, tinted windows, stock for now... -------- "Never slap a man that's chewin tobacco"
Posts: 8,142 |
Originally posted by Sleeper: I heard rumors of a few bad ones here and there, but never actually saw one. Never had a problem with mine, and neither did any of my friends. I believe the Class A 10.2 Amp isn't quite as powerful, but has a better S/N ratio. But I could be mistaken. I'm not too sure how prevelant the problem is, and like all quality issues, it was probably overblown. The Class A had a lower power rating into a 4 ohm load, but had the ability to produce the same power as the reference 1000 in high current situations.
Posts: 131 |
I really like your choce in subs. If it's in your range get a nice big Mcintosh amp. But if not I agree that the JBL BP 1200.1 is a great value for the power. Hope it works out well
'98 E0 T-RED CONTOUR SVT #558/6535 Got Tunes: Sony CDXC-90, CDXT-65, XDP210EQ MCINTOSH MC4000M BOSTON PRO 6.5 COMPONENTS BOSTON PRO 12.5 LF POLK DB4500 STINGER 1FARAD CAP RED NEON INSIDE AND UNDER THROTLE HANG FIX RESONATOR REMOVED
Posts: 408 |
I had a soundstream reference 700, and it caught fire after minimal use. However, I also had a reference 300 and it worked great.
vinny "2000 T-RED SVT" Mods: kkm sho shop off road y-pipe Audio: Alpine CDM 7874 Audio Control 4.1 EQ/Line driver Mb quart rsb 215 comp. Mb quart rsc 216 comp. blueprint 1001 sub 2 Phoenix Gold qx2180 amps
