#902726 03/17/04 08:47 PM
I did a search and couldnt find any information...
Does anyone know how or have a How-To on making the change tray by the ac vents into a gauge pod? If anyone knows, please let me know..
Thanks,
Ken
'00 svt #1485/2150 Precision SC6152E .63 a/r, PnP Heads, TiAL 38mm Wastegate, Blitz BOV, HKS EBC, and HKS TT, Koni's Front/Rear, 19" Centerline RPMs, SPEC Stage 5 Clutch and Flywheel, DMD, Intrax, LoTek w/ Water Temp, Oil Press., EGT, Boost Gauge
Well you need to take the dash off first and then go buy some ABS plastic or use some plexi glass painted black on the back to fill in the corners. I would first cut out the guage if needed in the dash. Oh remove the back tray part first. Next cut the plastic or plexi to the size hole. It may need to be flexed to shape by a heat gun to fit up close to the panel. That is what I am going to go with mine when I install my EGT in there but honestly you will need to play around with ideas on how to make it look good. good luck
99 SVT #198 blk/blue Spec 3/quaife/stage 2 shafts T3/T4 fully built 3.0 ported heads water injec./intercooled 13.2 @ 107 mph clifford alarm and turbo timer koni struts H&R springs intercooler for sale
Ok, cool...so noone has actually dont this yet?
I thought there may have been someone that did and I could get some photos off of it. Thats cool, I like creating
Appreciate the help!
If you check this thread on page 2: Simple Search Reveals...
Any further questions Ken, you can call me directly, you got my #, or try this: Search Page
PvVn3D! lol
99 T-Red SVT ***Intrax, Bilsteins, Azenis, Offroad Y, CAI, Tint, Magnaflow Exhaust, Custom Grilles, Poly Mounts, Silverstar Bulbs, 100W Ion Fogs, Focus SVT Wheels, SHO UDP, Ford Racing Wires ***
A simple search didn't reveal jack for me. And neither did your link.
Is search still broken?
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies--- +++JRSC M62 Under Construction+++ My big-a$$ mod list.
Yeah, I was thinking the same thing Bob but whatever..it was stated that I DID search but might not have used the appropriate keywords...Sue me. =)
I put that link there because it has a picture of the A/F in the coin tray, as well as 2 people (I-Dom-In-Ate & Warmonger) that have done that... figured you could PM them for some info on it. And Ken... u'll be hearing from my Lawyer
I put coin and tray in search and didn't find crap. I did look throught all of I-Dom's posts and came across this one...
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=genmods&Number=555787&Forum=All_Forums&Words=166&Match=Username&Searchpage=0&Limit=25&Old=allposts&Main=553929&Search=true#Post555787
HTH,
BP
