Ok, this should be pretty easy...
I got a BAT cone filter kit barely used off eBay. Since I've got a '95 SE, I have the IAT in the air filter box which is soon to be a permanent fixture on my garage floor, thus I need to put it in the air intake accordion pipe. BAT sells an "IAT relocation kit" for less than $3.00, but I figure I can do it myself since it appears to be nothing more than a bit o' hose an a T-connector.
Anyone have the specific dimensions (ID, OD, length, etc) that I need, or any other info? Correct me if I'm wrong, but I assume I tie both of the evacuation lines from the valve pan covers (or heads - whatever you want to call it) into one hose and connect that to the air intake pipe...
Thanks much.
1995 Contour SE 2.5L, ATX, Toreador Red
