#901734 03/16/04 01:45 PM
parisis Offline OP
98 mystique v6
Friends, I just got a new battery from our friends at Sears. A couple days later the CEL came on with the infamous 171, 174 lean both sides. Before I go into checking all of the possible solutions to this problem , is there anything the Battery installation could have done to cause this. I notice there are lots of wires coming from the battery terminals. Are there any vacuum hoses under there that could have been damaged? BTW the code has been reset once and came back on in a couple of days. Thanks for any help.
1998.5 Mystique LS V6
#901735 03/16/04 08:42 PM
Only likelihood of a connection is if the air tube between the MAF and the TB is not sealed or is damaged.
Steve
#901736 03/16/04 11:25 PM
O
O
air intake problem!It happen to me when I install an
aftermarket intake.I had to install the factory box to
pass maryland inspection.
New Pics of OUTKAST 1!Sept2006
#901737 03/17/04 02:27 PM
parisis Offline OP
Thanks all . I'll take a good look at the Air intake system.
Anything else?
#901738 03/17/04 10:29 PM
Originally posted by parisis:
Anything else?
Do that first. It is the only logical answer.
Steve
#901739 03/18/04 03:43 PM
parisis Offline OP
Found a sensor on the side of the air intake that was not inserted properly(Twist lock). I also amde sure everything was tight. Reset the Computer by removing fuse #11 , 3amp. So far ok with 5 restarts and 24 hours. Thanks.
