#900632 03/15/04 03:59 PM
When you guys installed your amp kits, where did you run the power/rca's? I just got my amp kit and was looking for some suggestions on where to run them. Do the front seats need to be removed? Thanks
AIM...BKapp17 98 T-red SVT Steeda Gutted Pre-cats, no resonator Painted Dash Angel Eye Fogs Painted Chrome ring / headlights Looking for a t-red pre98 trunk lid
#900633 03/15/04 04:16 PM
I ran the power down the drivers side and the RCAs down the passenger side of the car. And I removed the passengers seat.
"I'm not above the law, I'm beyond the law" 1999 CSVT Toreador Red Magnaflow Resonator and large K&N
#900634 03/15/04 04:53 PM
I ran the power cable down the driver's side and the RCA's down the center (under the counsel and carpet)
98' Contour SVT #607 of 6535 05' Mazda 6s Audio/Visual enthusiast because it's one of the many things I went through 4 years of hell for
#900635 03/15/04 05:07 PM
N
N
My power & remote turn on comes directly from my battery, so it runs through the engine bay, through the rubber grommet at the base of the windshield and then is routed under the driver's door rubber trim (there's a nice gap in there for the wires), around the B-Pillar, up under the side of the rear seat, and into the trunk where my amp is located up under the rear parcel shelf.
The RCA cables (need to be run away from power cables) are run from the HU along the passengers door rubber trim/B-Pillar, etc...
#900636 03/15/04 05:12 PM
Your remote turn on wire is on your battery? So your amp is always on?
#900637 03/15/04 05:12 PM
Captain Impound Boy
Captain Impound Boy
why did you run your REM from the battery?>
#900638 03/15/04 05:18 PM
Maybe he has a toggle switch
2000 SVT Black/Tan #1633/2150 (a few mods) Alpine: CDA-9835, MRV-F540, MRD-M550 PG: TANTRUM-X 6.5 COMP all around. Some people wear Superman pajamas. Superman wears Chuck Norris pajamas. CEL currently: Off
#900639 03/15/04 06:12 PM
me too.
you should hook the remote wire to something that turns on and off with the car. i hooked mine into the wire that turns the HU on and off when the key is in the on or off position.
if you dont do that, you need to put a switch of some kind on there so you can turn the amp off when the car is off.
#4559 of 6535 born on Feb 17, 1998 Black 1998.5 CSVT FOR SALE [cleaning house]: SVT rear swaybar. Reasonable offer and its yours!
#900640 03/15/04 06:36 PM
Captain Impound Boy
Captain Impound Boy
Your JVC doesn't have a REM out put?
Why would you use anything other than that or that and a Relay? Every aftermarket deck has a Remote turn on, or system control as its called on some.. There is no need to run your REM to a source..
#900641 03/15/04 07:23 PM
N
N
OOPS! I mean the main power is from batter. Remote is from back of HU, runs parallel to the power wire in the doors & trunk.
sorry about that confusion !
Moderated by  dnewma04_dup1
