sordz Offline OP
first i started out with 4 12" alpine type r's in my tour and it rattled horably(which i new it would) so i sold 2 of them now with 2 it still rattles bad and i have a dynamat trunk kit and a box that pushes most air threw the whole i cut in the back seat in armrest(you know behind when its up). please help im thinking of just down grading again to 2 10" subs or even 1. any info would help.
I
I
sordz,
Turn it down :p Try to figure out what part of the trunk is rattling. This would help us here to give you some ideas.
later,
Chris.
99 Se,MTX,TS.
Formerly Dieter88, TbnPlr
NEW ding guards !!
Welcome to the boards!! Not trying to be an a-hole but use the "search' button in the top right hand corner. This subject has been covered numerous times, you'll find alot of info on it there!
Again welcome!
rainshdw
rainshdw
1998 SVT EO #30
Born on 25 March 1997
UPDATED MY WEB PAGE
http://www.sounddomain.com/id/rainshdw
#1 easiest thing to help is to pulkl your seats down and let them have more air to breate. 2nd, I'd make sure your license plate doesn't rattle, if it does then the conventional napkin behind it can do wonders. As for the inside of the trunk, not much rattles except the spare tire ... I have dynomatted the whole thing and still it still rattles. Jared.
-SVTweeter-
http://svtitan.com - view the Ride!!!
98.5 Black SVT
PIAA blue platinum fogs,CATZ MSC in factory fog holes 18x7" Chrome Neeper Titans
KKM Induction, (4) 15 inch Solo-baric L7's in the trunk, (2)Earthquake PHD2 amps, Memphis 3004 powering (4) kicker 6.5 subs in doors,
Imaged Dynamic CD2 Horns powered by Memphis st150 amp.
5% tint around, side markers, Bassani exhaust, Ground Control Coil-overs w/ Eibachs,
Koni Struts & blackened back Reflector, B&M shifter
148.7 db May 6th - DB Drag
Yet to drag with new amps ... can't wait
shopping cart spoiler - I can fly baby!
9
9
You may want to check you bumber and wheel wells one of my buddies bumper was loose and rattled like crazy and a guy at the local stereo shop told me after dynamatting his trunk he figured out that his wheel well was causing the rattling confused never had either of those problems but just some advice
Quality is remembered long after cost is forgotten.
...Oh sorry I guess I am just another stupid kid who doesn't know anything...
Another fix for the license plate is one of two things. One, get some thin rubber washers to add just a little space between the plate and the holder....two, slightly bend the plate so that the bottom is not touching the holder. If you can, use all four licence screws and use the rubber washers.
Also, do like was said earlier. Listen with the stereo down and the highs off. Why you ask? Because you are listening for the beginning noise of the rattle.
Wanna hear something that really sucked? Had a 84 chev cavalier with this annoying rattle that was in the headliner. YES the headliner! Took a whole lot of a product called poly-fill used in making crafts and LOADED the headliner with it. Fixed the problem
Hope this give a little more help
Rich
'96 Mystique, Zetec, MTX.
---Mods---
Removed both intake resonators and airbox. Installed APC air filter and APC crankcase ventilation filter. Removed exhaust resonator.
Installed XM Satellite Radio. Replaced bad alternator and 175a fusible link...much fun!
Intake plenum---GONE!!!!
My car growls louder than yours.
If I can't buy it, I'll build it...Trust Me!!!!
I have the same problem since i replaced my Audiobahn subs with Crystal's.
I hope it don't rain all weekend frown
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
Sound by Crystal Mobile
Powered by a/d/s M860 AMP
My Ride
I used vel-cro for the licence plate...worked.
now the only rattle I get is from the plastic that lines the bottom of the trunk lid (where it closes).
does the dyomat work?
worth it?
later
"Corrasant--um that doesn't compute--um--wait--You're under arrest!!"
`00 Mystique GS
2.0 zetec
ATX
Ghetto air intake
12" rockford in the trunk
Is there a fix for the spoiler, I have been trying to eliminate all the rattles I can find and this happens to be one of tem. It rattle under the left side where it mounts to the top of the trunk , if I push down on it , it stops rattling.
Chris Bertrand , !!16 years young!!
1995 Ford Contour Gl 2.5 V6 MTX
My DIMS (DO IT MYSELF) Achievements:
Performance Mods: None
Audio Mods:Jvc head unit, 6x9's in all doors , Sony XM-752EQX amp, 2 Sony Xplod LS-1235 12" Subs
Video Mods:Blaupunkt DVD-ME1, 2 5" monitors in sunvisors
Aesthetic Mods:Neons, Streetglow El Shift Knob
Commando LCD Pager Alarm
Many Mods To Come.......
The best way to get all the rattles out of the trunk on a Contour... hmmm... two ideas come to mind...
1) Crush the car into a 1x1 foot cube
2) Put Contour badges on a BMW or Mercedes
I kid, but really it is an ongoing battle to stop all the rattles the Tour produces. At least it would be if I didn't sell it frown . The worst come from the rear dash panel, then the loose wiring along the trunk walls. Tape it ALL down the entire length of the wiring. Do this on the bottom of the rear dash as well. Cover the farting vents in the sides of the trunk, do the license plate and make sure the 3rd brake light doesn't touch the rear window.
As you go through the years of ownership, more will pop up as the car loosens more and more until it breaks in two or whatever they end up doing laugh
Moderated by  dnewma04_dup1
