Posts: 397 |
Originally posted by mcfast: Originally posted by rkneeshaw: Maybe someone already installed a larger rear bar in your car before you bought it?
It looks all stock. I think i am not the only one that his CSVT oversteers?
What tire pressures are you running?
T-red E0 SVT
ATS 17x7.5 Comp Lites, 215/45/17 Falken 512s, Ausi Bar, Boxed subframe, Poli all around, Warmonger's Opt Y, Opt TB, AFE, DMD, NGK's, Bendix Ti, Alpine, Polk, Mobil-1 0W-40, Redline MTL.
Posts: 300 |
Originally posted by SVT Doood: Originally posted by mcfast: Originally posted by rkneeshaw: Maybe someone already installed a larger rear bar in your car before you bought it?
34psi front 32psi rear Goodyear F1 225/50/16
SVT 99 #526 of 2760
Posts: 397 |
Hmmmm...that's pretty much where you want to be. I run 33F and 32.5R, and I never oversteered until the Ausie hit..then she'd come around real easy.
T-red E0 SVT
Posts: 300 |
Originally posted by SVT Doood: Hmmmm...that's pretty much where you want to be. I run 33F and 32.5R, and I never oversteered until the Ausie hit..then she'd come around real easy.
The oversteere is not bad just when you push to the max the rear comes around real easy and it is easy to control. But like i said these cars have more oversteere then understeere. Most of the front wheel drive cars i had understeere a lot. I like the handling of my CSVT
SVT 99 #526 of 2760
Posts: 1,469 |
I suspect the oversteer was a result of lifting off the throttle...When the back end starts to rotate with FWD, standing on the gas a bit will straighten you out, pointing in the correct direction (if you are good). 'course, you need to factor this into your plan when you chose your curve entry speed...getting on the gas at 100 MPH in a turn is a bit harry if you are wanting to scrub speed...
RWD cars understeer with throttle closed..which is more comforting in general. But the really good FWD car drivers use the rotation induced by lifing throttle to point the car around the turn...so it can be a good thing.
Stock SVT is mild-mod understeer under "typical" driving conditions. With more tire pressure front, stiffer rear bar, less rear weight can move the balance toward light understeer with easier oversteer.
1999 Amazon Green SVT Contour (#554/2760)
"People demand freedom of speech as a compensation for the freedom of thought which they seldom use."
-Soren Kierkegaard (as posted by Jato)
Posts: 300 |
I will get a lite oversteer when i go in a long hight speed corner and slowly go fast and fast until one end steps out and it is the rear that steps out before the front.
SVT 99 #526 of 2760
Posts: 4,149 |
The amount of fuel you're carrying can also have a significant effect.
-- 1999 SVT #220 --
Posts: 536 |
I had that problem. Solution, Slow down hot rod!, JK LOL, I still have that problem.
99' SVT #811 of 2760
Born on january, 12, 1999.
"This may have been his only shot at number one, but he just sucks on so many levels that I couldnâ??t even let him win a contest of suckiness."
Posts: 375 |
Now some of the more experienced can chime in here, but i believe that our rear suspension design incorporates a limited amount of rear wheel steering that allows for the oversteer condition. This is very desriable in a FWD car, as nearly all of them have understeer diled into suspension design, which is great for ma and pa, keeps them from freaking out when the rear starts to pass the front.  But as i was saying, most will plough when pushed, where ours 'gets its rear out' to help steer the car around the corner, not into the guardrail. It does this in a rather sudden fashion if it's not something you've experiencd before, but is very manageable, easy to control, and it does give you a fair bit of notice before it breaks, it's just that you're going really really fast when it does! And remember, esp if you're learning... DO IT ON A TRACK!!  Regards, -John
96 LX 3.0L MTX - Black/Tan
K&N; 12lb F/W & uprated clutch
2.5" Pipe; SVT bits; Mystery Mod; Pull-tie Mod;
UN-tuned Mod; 3rd Gear Synro-Crunch Mod
280K on the Shell, and 40ish on the Motor... 1/4 mile??
Yeah, it's a fun daily driver...
Posts: 383 |
Originally posted by Dan Nixon: I suspect the oversteer was a result of lifting off the throttle...When the back end starts to rotate with FWD, standing on the gas a bit will straighten you out, pointing in the correct direction (if you are good). 'course, you need to factor this into your plan when you chose your curve entry speed...getting on the gas at 100 MPH in a turn is a bit harry if you are wanting to scrub speed...
Took the words out of my mouth...classic lift-throttle oversteer and yes the fix is counterintuitive...
RWD is subject to the same laws of physics and if you snap off the gas in a RWD car in a turn, it'll rotate just like a FWD car will. The difference in behavior comes from what happens when you give it too much gas to fix the problem. In a FWD car, you'll understeer, and in a powerful RWD car, you'll oversteer. But generally they'll both respond the same to moderate throttle input.
Pacific Green '96 Contour LX V6
â??98 GTP, light mods, 14.66/94
Calypso Green '92 Mustang LX coupe, 13.56/101
Crown Autocross Club 1999 Street Tire Champion, 2000/2001/2002 Street Modified Champion
KCR SCCA 2002 Solo II Street Modified Champion
