I am building a false floor and a box. I plan to have a sealed box with a plexi back and a mirror floor (inside the box). I am getting some movement when I take corners hard and am wondering what you experienced guys do to secure the box so that it doesn't shake and roll around.
And another issue, but closely related: how do I secure the false floor to the trunk floor and minimize rattling/buzzing?
I am using 3/4" ParticleBoard and it doesn't seem to take well to the screws+vibration.
BTW, I am installing 2 12" MB Quart Premiums facing the front of the car (flush with the folding seats) and the ams will rest on a frame in the spare well. With any luck, I will have a clean install with only the chrome on the back of the subs showing.
Another issue: I know that amps run hot and turn themselves off (or cheap ones overheat) when they don't have any air circulation. How do I arrange it so that the ams don't suffocate in the well below the false floor? Can i route a hidden tube+fan to feed the amps cooler air from elsewhere in the trunk?
Any help is appreciated.
Have you put in your $0.02 to save contour.org?? Put in what you can spare to keep the site up. Check the General Forum.
David
* 2k Black SVT on 17" Konig/Yokohama
* MB Quart all around; Alpine 7995, DEI/Alpine amps; Dynomat
Soon to come:
19" HRE 445s under GC/Koni Setup, Custom passive-AWD kit, 2 small Sequential Turbos running low boost, Sequential 6-speed, Widebody Kit, custom black-red chameleon paint; on and on...
9
9
Custom install; Fiberglass. Doesn't move a bit wink
~^DJ^~
Quality is remembered long after cost is forgotten.
...Oh sorry I guess I am just another stupid kid who doesn't know anything...
Ray Offline
hey.. as far as the circulation goes... do what I did... I ran a hose from underneath one side of the car, up to the opening that is located in the quarterpanel of the trunk (one on each side.. has a vent on it...)
I just ported forced air (from moving) into there, by facing the hose "forward", and then routed the OTHER hose from the vent(passenger side) to outside the car, facing backwards.... created a "cyclone" of air in my trunk..
Of course, this option doesn't help you if you are sitting still, say, at a car show.. so.. I then cut the intake tube in half, and bought two small 12v fans, and mounted the cut tube to either side of the fans. now.. if I am still, I switch on my fans, and THEY force the air in..
GREAT results.. sometimes I wish I were in my trunk, driving, as it is actually cooler in there, alot of the time..
Ray
Check out my car!! (Profile Registry)
Have a Nextel two-way? check out my registry for my number!
Ray Haralson
Jacksonville, FL
s_r_haralson@sar.med.navy.mil
srh@texas.net
YIM: midnghtflm
AIM: midnghtflm
NEWEST MOD: a BEAUTIFUL girlfriend for my one and only passenger.
Moderated by  dnewma04_dup1
