Posts: 611 |
Its a conspiracy! Both cougars I've worked on haven't had knock sensors even though they are suppose to. Its bizzar. The svt I just fixed up with a 3L had one.
1999 3.0L Cougar: 220fwhp and 200tq
2003 VW Passat W8 with 4 Motion AWD
http://www.cardomain.com/ride/300644
PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
Learned patience the hard way
Posts: 2,454 |
I can see in the second pic where it's supposed to go. In any case, I'd be a little hesitant to run without one, but on the other hand if it starts going off, you've probably all ready done some damage.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Posts: 294 |
Originally posted by Buckshot77: I can see in the second pic where it's supposed to go. In any case, I'd be a little hesitant to run without one, but on the other hand if it starts going off, you've probably all ready done some damage.
Rick
Rick
You seem to be under the impression that CougarGT and Blackcoog are simply choosing not to hook the knock sensors in their cougars up.
This assumption is incorrect.
They are saying their cars do not have knock sensors, nor are there any provisions for one in the wiring harness, thus making hooking up a knock sensor impossible.
For the record, my 2002 Escape engine does have a knock sensor.. I have no idea if my 2001 Cougar has one.
~nick
2001 Cougar V6 MTX
3L Cougar.
Posts: 2,454 |
I had not seen one without a knock sensor. The 99 cougar I worked on and the Roush Cougar I worked on both had them. I guess ford decided to decontent them in the latter years of the cougar then. In either case, I would most likely bet that the threaded hole is there in the block. Whether or not the harness has a plug for it, that's another story.
Rick
Buckshot77@msn.com
Posts: 352 |
My '99 Cougar has neither the sensor nor the wiring harness for one? ![](/ubbthreads/images/graemlins/crazy.gif) Build date 11/6/1998.
Dan G. and his Cougar
Forged internal (Diamond & Pauter) full 3L, "Monster" Kinger F/I cut & P&P, T3/4 60 trim .82A/R ADC turbo, SPEC Stage 3, Torsen, Greddy Profec-B SPEC II, Apex'i Timer, Lots of Gauges!
Used to have: 3.0L SVT hybrid
Posts: 53 |
Originally posted by DanG: My '99 Cougar has neither the sensor nor the wiring harness for one? Build date 11/6/1998.
My car was made 6 days before your's ![](/ubbthreads/images/graemlins/smile.gif) Perhaps Ford forgot about the knock sensor that month
Ex Owner - 1999 Melina Blue Cougar
3.0L/SVT Hybrid
Posts: 352 |
Originally posted by CougarGT: Originally posted by DanG: My '99 Cougar has neither the sensor nor the wiring harness for one? Build date 11/6/1998.
Ford... Where quality is Job #1.... hundred fifty-seven thousand five hundred sixty three! </rant>
Redneck Troll
Redneck Troll
Posts: 2,621 |
My '99 Contour SE didn't have a knock sensor either...
http://www.bnmotorsports.com
