Posts: 2,725 |
I was reading that and got a question.
Does this refer to the trunk wont pop up, or open at all? When I turn the key, or release it from the inside the trunk just makes a clunk, but I have to lift it all the way up, it doesnt go up at all.
So I need to get that part then correct?
Posts: 3,345 |
Mine doesn't go up on it's own either. I don't think it's supposed to.
1996 MM
Zetec, ATX
192000 kms...not dead, but I'm not fixing it
White people love Wayne Brady because he makes Bryant Gumbel look like Malcolm X.
Smurfette
Smurfette
Posts: 8,770 |
Mine doesn't go anywhere. It just unlocks and then I lift it. I didn't think there was anything wrong with it doing that. the trunk lid is so light, I really wouldn't want it flying up.
Kim
1995 Contour GL
Needs less "needs more"
Posts: 459 |
Mine doesn't pop open either. It makes a thunk and then I just lift it up. Its always been that way.
98 Mystique LS
DOB 06/97
Posts: 937 |
I have to pull on it as I'm pushing the button or it wont open. Opening my trunk from the inside is a 2 person job. My trunk lid is heavier than normal because of the Dynamat.
Former owner: 1999 Contour SE Sport
Current: 2000 Eclipse GT
There are three ways to do things: the right way, the wrong way, and the Max Power way!
Isn't that just the wrong way?
Yeah, but faster!
Posts: 3,570 |
There's a trunk "popper" spring you can get from BillJ that is normall on a tauras that will help "pop" the trunk a bit. It definately doesnt make it open up on its own, but does give it more of a "pop" when you release the locking mechanism. Try a search, I have it installed on my car, works great!
Posts: 4,149 |
Originally posted by rkneeshaw: There's a trunk "popper" spring you can get from BillJ that is normall on a tauras that will help "pop" the trunk a bit. It definately doesnt make it open up on its own, but does give it more of a "pop" when you release the locking mechanism. Try a search, I have it installed on my car, works great!
Ditto, 2 minutes very well spent installing that little bugger!
-- 1999 SVT #220 --
Posts: 1,505 |
mine doesnt either im glad it doesnt cause it can loosen the heinges when it slams open
1999 Ford Contour SE Zetec with 137k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
