#89744 04/29/02 01:47 AM
V
vinny Offline OP
V
I just bought an audio control Four.1 EQ/Line driver. I was wondering if any of you have used this eq and what your thoughts were? It will be installed either tommorow or wednesday along with my new mb quart components. I'll post results afterwards. Thanks, Vinny
vinny "2000 T-RED SVT"
Mods:
kkm
sho shop off road y-pipe
Audio:
Alpine CDM 7874
Audio Control 4.1 EQ/Line driver
Mb quart rsb 215 comp.
Mb quart rsc 216 comp.
blueprint 1001 sub
2 Phoenix Gold qx2180 amps
#89745 04/29/02 03:13 AM
i want one!!!
Let me know how it turned out. I used to have a Linear Power PA-IIR...similar to the audio control. I loved thing, great flexibility
rainshdw
1998 SVT EO #30
Born on 25 March 1997
UPDATED MY WEB PAGE
http://www.sounddomain.com/id/rainshdw
#89746 04/29/02 07:46 AM
I just wanna say, i never did see anything wrong with audio control. I've seen a bunch of EQs being used along with their sound processors. I don't have one myself, but if i didn't get the symmetry, i guarantee would've gone with audio control. Just my 2 cents
Give me more beer and CEG before i get depressed!
AIM/AOL: DBZ Jr
#89747 04/29/02 10:24 AM
The 4.1 is great! Good choice!
#89748 04/29/02 01:31 PM
I have one. I have had it since it was released way back in 1996. Yes it is an old piece of technology. But is much better than almost all of the new stuff.
The Four.1 will put out 13.5V max (which can actually be achieved if you have a proper electrical system setup in your car).
It will put out a min of 11.5 volts with a crappy electrical system.
Install it and turn down the gains on all of your other stereo components (amps/crossovers/signal processors/etc.) and be prepared for a very, very noticable increase in volume and sound quality.
Definately a must for car audio.
The great thing about it is it's simplicity.
While a fancy digital EQ with is graphics and preset levels looks great, it is no where near as effective.
Almost all (there are a few expensive exceptions) digital EQ's work on a fix band design; so when you increase the level of 3kHz by 3dB, that is all that is adjusted.
Whereas the Four.1 works on a bell curve design; when you increase 3Khz by 3db you increase 2.7kHz by 2.5dB, you increase 2.5kHz by 2dB, you increase 2.2kHz by 1.5dB, etc.
This allows for better tuning of a system.
Also, digital EQ's increase signal levels in steps, 1dB, 3dB, etc.
Whereas the Four.1 (since it is analog) allows for much motre precise tuning, 1.1dB,1.2dB,1.200001bB,etc.
And as everyone should know, analog will always reproduce music better than digital, why, because music IS an analog signal.
1997 GL Sport MTX,
Soon to be the fastest proven Zetec around.
#89749 04/29/02 01:38 PM
Being a parametric EQ, I assume it has an adjustable Q that can effect a very small range of freq or a large range. As sleeper said, parametric eqs are great because of their flexibility.
#89750 04/29/02 01:51 PM
V
vinny Offline OP
V
Thanks for your responses guys. It will be installed wednesday, so i'll post the results afterwards.
Mods:
kkm
Audio:
Alpine CDM 7874
blueprint 1001 sub
Moderated by  dnewma04_dup1
