Posts: 48 |
My mom's fuel pump went out in her Mystique today. I plan to tow it home and change it myself, but I have a question: In the Haynes manual, it says there is an access plate in the floor, underneath the rear seat. Get to that, and you can change the pump without pulling the tank. Is this true? More to the point: is this true of '98- '00s?
Black/tan early '98 Contour SE Sport; dead-dead-deadsky (gone, split, outta here, afterlife kids)
'05 Pontiac Sunfire; 2.2L Ecotec, ATX, well-equipped
Mom also has black/tan '98 Mystique LS; V6, ATX, Alpine CD deck
Posts: 3,395 |
I know if you lift the back seat up, the fuel pump is there, at least its that way on my 95 Tour
Posts: 4,693 |
If you have a late 99 or 00 Contique with the returnless fuel system, it is a little harder. The hole in the floor did not get any bigger, but the fuel pump did. You must open the hole in the floor a bit bigger or you must drop the fuel tank for access. Even if you don't have the returnless system, you may learn something from this FAQ. http://www.contour.org/mods/mods.php?s=howto&displayid=39
Jim Johnson
98 SVT
03 Escape Limited
Posts: 1,228 |
Also, it is a big PITA to turn the lock ring off. Be patient, work steadily. I used a hammer and brass drift and slowly, ever so slowly, with light taps, managed to get it off. I tapped lightly all the way around on the raised portion of the ring. You'll see what I mean when you remove the cap under the seat. Don't get too muscular with it.
Aloso, the seat can be a little tricky to pick up and you may break the plastic clip that holds it in. Mine was already broken by the alarm installer. I didn't know until I went to repair my pump.
Also, get a new o-ring for the access hole. The original one will br stretched and won't fit back in. The O-Ring on mine was green colored, if it matters. I repaired mine but you have to know how to do this. WE have o-ring repair kits at work. I recommend a new o-ring.
BEFORE: '99 Contour SE Sport
Duratec ATX Spruce Green
Posts: 48 |
Mission accomplished! I dug into it yesterday, and it took me all of thirty minutes to change it out! And to think Reynolds Ford in East Moline wanted $250 for labor alone.  That translates into $500/hour. And they know about pulling it from the top, too.
Posts: 82 |
Congrats!
It is WONDERFUL to hear of a DIY triumphing over the evil forces of the $500/hr dealership ripoff!
1995 Contour GL "GEX"
2.0 Liter 4-banger
ATX
162,500 miles
Stock except for two '89 Tempo wheel covers & two VERY COOL cosmic looking '76 Toyota Corona wheel cover
Full size spare
No rust
Green
Purchase price: $500
Posts: 65 |
i had to replace my fuel pump in my 99 tour. The hole under the seat was to small so i had to drop the tank. Worst job ever. Everything was in the way. I finally got it out and fixed it and now i have another problem. When i fill my tank up with gas it leaks out the filler neck hole on the gas tank. I dont understand because i completely wiped the seal and the hole in the tank completely clean. Any ideas?
Posts: 403 |
You may have to bite the bullit and drop the tank again to get it on correctly.
96 Sport 2.0L - 190,XXX miles
Posts: 1,505 |
Originally posted by 1999sesport: i had to replace my fuel pump in my 99 tour. The hole under the seat was to small so i had to drop the tank. Worst job ever. Everything was in the way. I finally got it out and fixed it and now i have another problem. When i fill my tank up with gas it leaks out the filler neck hole on the gas tank. I dont understand because i completely wiped the seal and the hole in the tank completely clean. Any ideas?
hope you didnt brake that white round clip on the filler pip cause if ya did you have to buy the whole filler pipe
1999 Ford Contour SE Zetec with 137k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
Posts: 1,228 |
If you ever need to do the pump again, just cut the sheet metal under the seat. I cut 4 lines (radial) and bent up the metal. Bent it back down when finished and used duct tape to seal it.
