bkent Offline OP
Tried to track it down for quite some time with no luck. Anyone have an idea of what causes it? I almost sounds like it's up high and towards the front of the door confused
2000 CSVT #1172 of 2150
Toreador Red...Birthday -> 1/4/2000
*Indiglo Gauges
*Drop in K&N
*Sylvania SilverStar Highs in Lows
*Fog light Fix
*Pioneer Premier P730
*Sound by Audiobahn
*White HVAC Panel
*Security via Ungo MS2007
*Elky Mesh Mod
Hey I have some clunkly rattle from inside the passenger door too! Cant figure it out. I get a bit of squeak from the door pannel though.
I've got it in both doors, same spot as your describing. frown
It just gets worse by adding speakers with better bass response. I've got some 'Bahn 6.5" mid-bass drivers, and they can make the doors sound like beehives.
I'm planning an entire system tear-down with rewiring and sound deadening this summer. Should hopefully solve this very annoying problem.
1999 SVT #900/2760
Born on 1-20-99
Silver Frost/Midnight Blue
A few aesthetic and audio mods
It may be the wires running along the metal of the door. Up high and forward would be the wires for the mirrors. What I did was either silicone all the wires or tape them down so that they cannot vibrate against the metal and make noise. Occasional pieces of tape won't work, you have to run the tape along the length of the wire.
Now all my noise (which isn't much anymore) is related to the OE foam liner buzzing against the metal in a few places (mostly on really low notes below 40Hz). Always having to track down a new buzz. :rolleyes:
Bob Johann
a/k/a SoundQ SVT
1998 T-Red SVT Contour #3088
Member of Team Xtant
2001 IASCA Pro Street 1-600 World Champion
IASCA Sound Quality judge since 1997
Cheezy Website - http://www.sounddomain.com/id/soundqsvt
I have rattles everywhere.
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
Double check the bezel that holds the window/lock switches...and the mirror mount/defrost panel area. Where that stuff meats the dash piece tends to rub, rattle, and squeak...not necessarily in that order. wink
Is it a constant rattle or does it just happen in certain cituations?
rainshdw
1998 SVT EO #30
Born on 25 March 1997
UPDATED MY WEB PAGE
http://www.sounddomain.com/id/rainshdw
i have the same problem. i think it's the two metals pieces that the door handle screws into too. i tightend them about a month ago, and it disappeared for awhile....now it's back in full affect. it's quite annoying...
I don't know if it is - but still it may be a good idea - put a self-drilling metal screw in a little vent ducts that goes underneath a-pillars. These ducts aren't very secured in places unless you do it. Make sure not to use a very long screw - and have your windows rolled down while doing it.
Regards,
Kirill
98.5 Contour SE Silver Frost (powered by Duratec 2.5L)
Nakamichi CD-45Z -> Phoenix Gold XS4300 -> Infinity Kappa 693.3i
\_ Blaupunkt ODx694
Kirill...
where exactly are you talking about on the door....
Moderated by  dnewma04_dup1
