Posts: 228 |
I'm planning on doing a coolant flush, and need to know if the thermostat housing has a gasket, or if RTV sealant will be enough.
Thanks
Pablo Quintana
98 SE Sport Contour
Honduras, Central America
Posts: 625 |
it has a rubber-like o-ring, i think its technically a gasket. When you take apart the t-stat housing, its right there surrounding the actual thermostat.
98 SVT
#1652 of 6535
My SVT
"If everything seems to be going well, you obviously don't know what the hell is going on."
Posts: 228 |
I know bout the rubber ring, but that fits between the thermostat and the housing. Isn't a gasket like felpro ones between the two housing parts, or RTV sealant is enough?
Pablo Quintana
98 SE Sport Contour
Posts: 1,085 |
No, just the O ring, I know , I know you ,want to put goo on it....but thats 'OLD school'....
2012 Lotus Evora
95 Mystique MTX - GONE 395,000 Kms
--------- Both Zetecs
'97 Contour Mtx - stock - GONE
Posts: 1,788 |
No goo, just the O-ring.
I found that rolling it onto the flange of the outlet tube made it easier to get installed properly. It only took me three tries over six months to get that one right.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 888 |
if you are planing on replacing the thermostat then make sure you get the O-Ring for the thermostat... you dont put anything on it, just the O-ring inside the fitting........ depending on how long it has been on there you might need a new one if it was crushed for a long period of time......
