Posts: 4,155 |
Decided last minute I'm going with the LIM from a 2000 CSVT. I'll buy from SP Motorsports, just a question though:
The whole 19 ilb injector deal. It'll come out more expensive to swap out all the green topped ones for the 98 model ones. Should I just buy the harness listed for $100 bucks or is there a way to hook myself up and save cash?
Any info is appreciated guys as always thanks
Bill
Posts: 6,760 |
I'm kind of confused, but I think your asking basically if the 19lbs will work with the 96? or even new new LIM? I believe as long as you use your previous fuel rail you'll be ok. Should just plug and play.
Ryan
Trollin!
Posts: 7,025 |
everything that comes with the spmotorsports 2000 svt lim is for a return style car. Remember, these are factory mistakes so everything is a direct swap.  However, when i swapped in my 42lb injectors i did have to splice a couple wires to get the harness to work.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 449 |
Heads up guys ... but I bought one and the openings were the SAME size as on the one already on my 98.5.
98.5 SVT now gone ... new wheels = 2005 330i
Posts: 2,676 |
34/35mm?? that's the size of the '00 ones. . .
Posts: 449 |
That's what SP sez they're supposed to be and they're 32/33 mm instead.
Posts: 9,602 |
If you just wanted the returnless LIM (33.5mm/35mm) you could have bought one from car-parts.com for ~$100.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 397 |
Is this the one from the 2001 Cougar?
Will the clips from the return style injectors fit the new returnless injectors or are we talking splicing?
T-red E0 SVT
ATS 17x7.5 Comp Lites, 215/45/17 Falken 512s, Ausi Bar, Boxed subframe, Poli all around, Warmonger's Opt Y, Opt TB, AFE, DMD, NGK's, Bendix Ti, Alpine, Polk, Mobil-1 0W-40, Redline MTL.
Posts: 449 |
Demon - you're right ... never even crossed my mind to go used.  The new one is supposed to be a 1999 LIM, but with the return style fuel rail - ie. the larger ports to better match my freshly extrude-honed UIM. In the end, I got the new one optimized by local guys Performance Fords and will keep. You know it may be a moot point anyway to go larger on the LIM side as the UIM ports that match to the LIM ports were smaller in size when I put the 2 manifolds together off the car.
Posts: 9,602 |
Yes, but ANY returnless Duratec will have the largest LIM
No, why do you need larger injectors anyway?
2000 SVT #674
