Page 2 of 2 1 2
yea that can be a sign of a worn thermostat. Start with the coolant flush using a prestone flush solvent or similiar and go from their....
2000 Contour SE Sport V6 Duratech Alpine MP3 CD Head unit 20% tint AEM Short Ram Intake
W
W
Originally posted by MarkO:
Do you know what the actual coolant temp differences are due to the WaterWetter ??
Just curious.
http://www.redlineoil.com/whitePaper/17.pdf
Whirling dervish of FFOG.
Zoe,
If you're converting coolant you have to be careful. The Dexcool type does not mix with the standard anti freeze. If your system (including heater core) is fully flushed with water it should be no problem. The Duratec has no engine block drain so it is time consuming to get absolutely all the old coolant out.
'98 LS MTX
Page 2 of 2 1 2
