Posts: 146 |
so dave, how about those clarion's I posted above (there's a link I believe), any thoughts on those?
1998 black Contour SVT E0 -KKM Intake -Magnecor 8.5 mm spark plug wires -Bosch +4 platinum spark plugs -B&M Short Shifter -SPARCO front strut tower bar -17x7 Rage 5.0's with Nitto NT450's (215/45-17) -24mm Aussie rear sway bar
Posts: 8,142 |
I don't have any direct experience with them, but I haven't really come across a poor product by clarion. The seperate crossover is an encouraging feature.
Posts: 8,142 |
Posts: 983 |
Speakers: Infinity or JL Audio Decks: Alpine Amp: PPI
that is all i have to say about that.
1998 Vibrant White 2.0 Zetec / "Powered By Ford" Shoulder Pads / 3A Racing Pedal Covers / Pre-98 Sail Panels / Alpine SPS-5729 in the front / JL Audio TR570-CX in the Rear / Zetec Inside Sticker / Replica Porsche 944 Rims (5 circle ones) / CEG Sticker / Super White 9006 Low Beams / Euro Style Short Antenna / Broadway Wide-Angle Mirror / Painted Front Grill Vibrant White / CTA Intake / Accel Ignition Coil / Diablosport Chip / Dynomax Super Turbo Muffler / Ractive Amber Side Markers / ST200 Struts / Eibach Springs
Posts: 146 |
All of this info has been good, it seems that the general consensus is that infinity rocks house. Dave, I really do respect your opinion, just wondering what you think about infinity speakers as well, eh?
Posts: 8,142 |
I don't have a problem with any infinity speakers.
Posts: 491 |
Infinity speakers are great. I currently have 6.5" mids w/ 1" tweeters in front and 6"x8" in rear. The sound, volume, and staging are great. I would recommend the "Reference" series.
1997 GL Sport MTX, Soon to be the fastest proven Zetec around.
Posts: 491 |
Image Dynamics produces the only horn drivers that will accurately reproduce the frequency range of 120Hz-15kHz. (This is the full spectrum of human hearing) Subbass = 16-32Hz Bass = 32-128Hz Midbass = 128-512Hz <-- Midrange = 512-5096Hz High = 5096-20384Hz
Posts: 8,142 |
Originally posted by Sleeper: Image Dynamics produces the only horn drivers that will accurately reproduce the frequency range of 120Hz-15kHz. (This is the full spectrum of human hearing) Subbass = 16-32Hz Bass = 32-128Hz Midbass = 128-512Hz <-- Midrange = 512-5096Hz High = 5096-20384Hz You must only be referring to car audio products when you say they are the only company to produce horns that play from 120-15khz. The limits of human hearing is generally considered 20khz. There are a few non horn drivers that will play from 50-18000 with a single radiating surface (no tweeter) and one that will play from 100-20000hz. I have no problem with the ID horns, but they are not THE best on the market, they are one of the best. One of my problems with them is there wildly varying FR that requires the use of a 1/3 band EQ to flatten to a reasonable level.
Posts: 8,142 |
I misread your last post about the human hearing thing. I thought you were insinuating that the ID horns played the full spectrum of human hearing.
