Posts: 1,475 |
Originally posted by PackRat: I could give a [censored] which wheels drive my car. Get over yourselves.
Gee what's your problem? You probably don't even know what wheels drive your car do you.
RWD under $30K - what about a used 3 seiries Bimmer. Better yet, used M3!
"Absolut Rara."
"Absolut Rara."
Posts: 3,223 |
You need to spend some time at a driving school and then see if you still feel the same way.
I know the infamous Dew truck wasn't FWD . . .
Posts: 3,193 |
Originally posted by Pigeon: Drive a good RWD car aggressively at an autocross or a track, then tell me that FWD is dynamically even close to RWD. Go drive an Acural TL 3.2 and tell me that you enjoy torque steer. RWD is far better in nearly every respect than FWD, the only advantage to FWD being in snow traction where the weight being over the driven wheels helps initial acceleration.
Now, as to where the car is made, that I don't give a rat's a$$ about. Just make it quick and cheap.
Scott
I have driven both my RX-7 and my Contour aggressively at autocross and track events, and I will say that the dynamics are equal. Very different characters, but equal dynamics.
The RX-7 feels like a slot car, though I believe that is aided by it's firmer tuning, smaller size, and go-kart driving position. However, it bites without warning. A little too far, and say good-bye to the tail.
The Contour is much more linear in its behavior, the input you give is proportional to the response you get. The car tells you when the limits are being reached. I am far more confident pushing the Contour to the limits than the RX-7, because it lets me know when I reach them (a slight wigging in the rear suspension). However, the car is more deliberate in its handling response and plows over the limit when stock, it can be tuned to have some tail swing.
I must say torque steer is the whipping boy of FWD haters. I flogged a 2004 Acura TL on Saturday, and while I noticed it a little, I did not find it objectionable. You just treat it like an internal skid, and keep the car going where you want it to go. It was much less hairy than when I took a Lincoln LS V8 Sport almost sideways on the same turn driving it approximately the same way. I did the same thing and steered where I wanted the car to go.
I believe that FWD and RWD have different, though potentially equally good, dynamics. I think the engineering of the car to build its personality has a lot more to do with the driving quality than the wheels chosen to drive the car.
That said, it's really a matter of taste which characteristics you prefer to drive with.
Brad "Diva": 2004 Mazda 6s 5-door, Volcanic Red
Rex: 1988 Mazda RX-7 Vert, Harbor Blue.
Posts: 4,899 |
Originally posted by Pigeon: Originally posted by PackRat: I could give a [censored] which wheels drive my car. Get over yourselves.
Scott
I don't track nor do I care to thank you very much.
Posts: 4,899 |
Originally posted by Rara: Originally posted by PackRat: I could give a [censored] which wheels drive my car. Get over yourselves.
Yeah and it couldn't do over 66 mph either.
Posts: 1,201 |
The new Turbo Miata will be sub 30K. Should be a fun little buggy. My '03 was 17K. Base model (whch included CD, power windows, mirrors, glass rear window, rear defronst, fog lights, power antenna) with 16" alloy wheels, LSD, Bilstiens, upper strut tower bracing, 10.3" front brakes, 10.9" rear brakes.... Fun little package and one of the most reliable cars ever made.
Posts: 3,193 |
A Renesis Miata is also on the way... I don't have the year or the price, but reliable confirmation.
"Absolut Rara."
"Absolut Rara."
Posts: 3,223 |
Originally posted by svtcarboy: Originally posted by Pigeon: Drive a good RWD car aggressively at an autocross or a track, then tell me that FWD is dynamically even close to RWD. Go drive an Acural TL 3.2 and tell me that you enjoy torque steer. RWD is far better in nearly every respect than FWD, the only advantage to FWD being in snow traction where the weight being over the driven wheels helps initial acceleration.
Scott
Sorry James, you are comparing apples and potatoes. All things considered, RWD is superior in performance to FWD. That doesn't mean a FWD can't feel good or even be quick, but there is a reason that engineers starting from scratch always choose RWD for a performance application. (AWD is a different story, and is like throwing a cabbage into the comparison)
Posts: 3,193 |
Brian... I think we define performance differently.
The definition of "what is good" in terms of anything is what drives the rest...
Don't even get me started on AWD...
Posts: 375 |
find a nice Datsun 510 and drop a SR20 in to it. that has always been a dream of mine...
Alex T.
98.5 Silver Frost CSVT #5510
05 Nissan Frontier Nismo 4x4 6 speed
85 Bronco II 6" lift 302 swap
