mine stopped working, due to a refrigerant leak.
shoot some dye in there and check for leaks.
ford covers some of the components, and lines with foam insulation, which traps in moisture, and causes them to corrode, so you may have to peel some of it off, to find the leak. (mine was the rec/dryer)
