Posts: 219 |
WHere are your gains set?
later,
Chris
99 Se,MTX,TS. Formerly Dieter88, TbnPlr NEW ding guards !!
Posts: 411 |
I set them the whole way down on the fronts to eliminate as much of the sound as i can
99 Tropic green svt Custom Stereo borla cat-back 22mm bat rear sway bar custom K&N & heatshield 215/40/ZR17 Rubber jimmkreider@yahoo.com
Posts: 1,083 |
did you checkthe power wire like i asked earlier? Make sure it isn't crossing any other rca wire?
1998 SE ATX Dual exhaust Body conversion Nakamichi CD-40z HU Sound by Crystal Mobile Powered by a/d/s M860 AMP My Ride
Posts: 411 |
Well I didn't specificaly check it, and this is why: Like I said before, I checked the RCA's and it wasn't them. I did this by popping out my head unit, running a different set of rca's from my head unit to the amp under my seat. Doing this, my RCA's weren't even near my power wire...hmm....another thing i'd like to point out.....my 4 gueage power wire runs along side the drivers side, and then i split off with 8 gage and ran it over to the passanger seat....maybe something went wrong there????
Posts: 219 |
Could it be originating at your Head unit? Did you install it?? If no or whatever sheck to see that it is gorounded through the harness or directly to the chassis of the car. Sometimes installers will use the antenna as a ground to "Speed thing up". This works but eventually gets bad. IMO and experience. Take a looky there.
Later,
Chris
Posts: 53 |
While playing a song on your cd, unplug both your right and left rca's from the amplifiers. If you still hear the buzzing then it is coming from your amps if you don't hear it anymore then it is coming from your head unit.
1998 Silver Contour SVT 17x7.5 Quantum Tech S-13 Rims Nankang 215/45/17 Lo Tech A Pillar pods Resonator Removed Panasonic CQ-DFX701U MobileTV Hi-Fi VCR MA-Audio DVD Player MobileTV 6.4" LCD (2)Xtant X415 subs (2)JBL BP1200.1 (2)A/D/S 250MX Phoenix Gold XS160 Components Audiobahn crossover Auto Meter Phantom Gauges Bullit Fuel Door B&M Short Throw Shifter Ichibahn REV Series Steering Wheel
Posts: 219 |
way to simplify it man! I like this approach. also, if you decide that it is coming from your H.U., that will include your patch cables.
Later,
Chris
Posts: 411 |
well, it only comes through my front speakers, which are amped. The rears are not, and they don't make any ugly noises :rolleyes: As far as the head unit, I didn't have any trouble with it in my other car....and there is no noise when the car isn't runing. The noise I hear in the speakers comes straight from the engine. I can even hear the sound of the fan running...? Where is the headunit grounded?(i installed myself) and if the headunit's ground was bad, wouldn't the back speakers make that noise too?
Posts: 53 |
No not necessarily. If you have a bad ground to your head unit it may not be noticable going from the head unit to the speakers. But if you amplify the signal through your amplifier then it would be more noticable. Unhook your rca's from the amp when you are playing a song first. Its just a matter of process of elimination.
Posts: 219 |
99bad,
Umm, Try and power down the rear amplifier and leave the front one connected. Do you still get the buzz?
