Posts: 2,728 |
My car has 106,000 miles on it. The engine has about 55,000 and the trans. has a little over 15,000. I'm going to replace the plugs and wires, suspension, exhaust and have it dyno tuned. Any other suggestions on things to replace or clean? I might try and clean the UIM while I'm replacing an O2 sensor this weekend. Oh, and the waterpump was already replaced.
'03 SRT-4
50 trim turbo + support
Posts: 120 |
Posts: 6,700 |
An EXPENSIVE bottle of fuel system cleaner (like, mobil 1 syntec $13.99). Do a general, "hmmm, this don't look, sound, or run right" scan and fix em. Clean that air filter (if not yet done), and give it a good wax job, it deserves it!
2006 Pontiac G6 3900SFI GTP Coupe
CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint
Former Owner- 2000 "Stryped" CSVT
CEG Dragon Run- Oct 13-15
Posts: 1,660 |
Dyno tuned? You've got a custom chip?
Scott
Troll! '99 BMW 328i
Posts: 2,728 |
Originally posted by Pigeon: Dyno tuned? You've got a custom chip?
Scott
Odds are I will when I'm done with that...
'03 SRT-4
Posts: 1,660 |
One item to add: change out all the fluids - brake/clutch, PS, coolant. Trans youcan probably leave with only 15k on it, depending on what's in it. I prefer MTL, if it's ust got ATF in it then change it. Also change the belts.
Scott
Troll! '99 BMW 328i
Posts: 2,728 |
I'm getting the synchros and shift forks updated next week. I don't know off hand what fluid they use. I'll find out.
'03 SRT-4
Posts: 8 |
Don't forget your Cabin Filter
Posts: 2,676 |
I like Lukas Oils Upper intake cleaner, Its the only fuels add that I use. I would do fuel filter, cabin air filter, oil, oil filter(duh), plugs, and perhaps wires. Then just take a look, see if your belts look good, not frayed. And look for any wires that are exposed. Anyone else? Oh and Air filter in your air box.
Posts: 6,700 |
If you haven't had it done in awhile, get those wheels aligned and balanced... even if everything feels fine, a very slight offset can slowly turn bigger. It amazes the hell out of me how many people turn in their lease cars at my work with 20-40,000 miles and the suspension is just shot to hell, squeaking, rumbling tires, popping steering, horrid looking tires. Its like, Bajesus... It just takes $60.00 once a year for a rotate, balance, and alignement; it isn't that freakin bad! Instead, they'll be paying hundreds in repair bills when GM gets their car back.  Hmm, probably a given... check your tire pressure. Its getting warmer and the tire pressure is changing.
