#88915 04/09/02 02:55 AM
Doug C. Offline OP
Do I have to drill any holes to get through the fire wall of a 98 mtx? If so where would be a good spot? Also how do I run the cables past the back seat into the trunk? I have never done this before, and got a good deal on a amp, and sub. Any help would be a big help.
try the search button, but there was a picture of someone that had it .. heres a link to some other cabling topics.
here
and for the cabling. i ran the power wire along the side plastic panel were the weather stripping is. the rca's and remote under the middle console. and cut a slit in the carpet and drug the cable under it and under the backs seat .. and grounded it to the frame(drilled hole)
Alcohol is my friend
Mongolian BBq S.H.
Doug C. Offline OP
thanks
Moderated by  dnewma04_dup1
