Posts: 2,382 |
Originally posted by 97Duratectour: I'm hearing a rather quiet knocking noise comming from the front right portion of my car when I hit bumps/pot holes. I don't know if this might be a shock, or maybe a spring but it is really getting on my nerves because it's all I listen for now when I'm driving? Any past experiences with similar problems, or noises?? Any help is good help right now!!! Thanks
Going over bumps & such?
If you've never replaced the front sway bar end links that could be them. When they go they make a quick knocking sound that seems worse over smaller bumps & such. They seem to fail a lot. You'd never know they were bad, they don't tear or anything. They just go bad. O'Reilly sells them (cheap) and they install pretty easily. Just need two adjustable wrenches. If you're not too sure on how to do it, any shop can put it on and they'd better not charge much since it's easy
"Fear is the little death."
Muadib.
