Posts: 11 |
Trying to start contour for the car show and it cranks but doesn't fire, I don't hear the fuel pump prime. have checked fuses so I was wondering if having a dead battery will do something to the security system? any ideas? Sean
Posts: 130 |
Here's what happened to me. But I have no idea if it's the same problem with yours... Click here
1998.5 SVT Contour - Black
H&R's
Optimized Y-pipe and TB
Open element intake w/heat shield
18x8 Mas Italy Axels (40 offset) w/225/40/18
2x Kicker 8" midbass "subs" in rear deck (infinite baffle setup)
A few more little things...(like bushings)
Posts: 130 |
Oh wait...you don't hear the fuel pump...nevermind. Something completely different then.
H&R's
Posts: 11 |
Thanks , I'm going to get it scaned in the morning and see what comes up. Sean
Posts: 2,974 |
Are you entereing your car in Performance World? What colour is your SVT. It could br your alarm I know of people that the alarm malfunctioned as a result it activated the ignition kill mode.
Aaron
AKA NVS SVT
98.5 Silver/Blue SVT#4553
Yeah it's modded
98 T-Red/Blue SVT Contour Totaled 06/05/06
03 3L,VCN 2000,CAT Cams,MSDS Headers w/Y-Pipe,XCal2 and lots more
Posts: 993 |
The car does turn over, everything works but it just doesn't want to start. I am keeping my fingers crossed as yes, his car is going to Performance World, if it will run for us that is. He is part of our clubs display. Everyone needs to keep all fingers and toes and pray before you go to bed tonight that it isn't too serious and can be easily fixed. Okay
1998 BLK SVT CONTOUR
#2980 of 6535
395,000(ish) km (and counting)
SVTOA-TORONTO
Chapter Director
www.svtoa-toronto.ca
Posts: 2,807 |
If it's been sitting for a while I would guess the fuel pump is shot. That's what happened to the guy who sold me my SVT. It had been sitting for the winter and when he tried to start her in the spring it was a no go. Check the emergency fuel shut off on the kick panel of the drivers side fire wall just beside the dead pedal, it could be tripped.
99 CSVT Green/Tan
# 84 of 2760
15.376 @ 92.00 MPH Stock
75,000Km
96 Contour GL
2.5L V6 ATX 170,000Km
Posts: 47 |
Just went through the same problem... needed a new fuel pump and some idle control semsor!!
15.639 88.63MPH
SVT Driver
Posts: 11 |
yes siree fuel pumps gone... Found on road dead... well I guess 17,000 kms for a pumps not bad!!!!! thanks for youre help guys and I'll see you at the show. Sean
Posts: 2,807 |
It's the idle time that kills them. You should start the car up every once in a while when it's parked. The fuel pump on my car was replaced at 10,500Km for the same reason. Let me guess it was about $700 to get it replaced.
99 CSVT Green/Tan
# 84 of 2760
75,000Km
96 Contour GL
