Posts: 339 |
If they clean all of that for $119 I'll eat my hat!!!!
Mondeo V6 RS
RS Bodykit
RS Lowered
SVT UIM
SVT TB
SVT LIM
Philips 6000K HID ZENON
Twin Stainless Exhaust
Posts: 7,117 |
Originally posted by Mondeo V6: If they clean all of that for $119 I'll eat my hat!!!!
I'm thinkin'... We'll see.
Posts: 2,163 |
I made a appoitment to take the car in on wednesday 3.12.2004 to Ford to have this LIM, UIM, Heads, fuel rail, injectors, EGR, and TB cleaned. I hope that this type of cleaning will all be included in their emission's tec for $119. I will let you guys know of the results.
I guess I will have my mounts changed at another time for $800+ because I do not know what the cost of the above will be.
Posts: 7,117 |
Originally posted by contour_phoenix_when: I made a appoitment to take the car in on wednesday 3.12.2004 to Ford to have this LIM, UIM, Heads, fuel rail, injectors, EGR, and TB cleaned. I hope that this type of cleaning will all be included in their emission's tec for $119. I will let you guys know of the results.
Get a quote from the service writer to protect yourself. These are all just cleanings & labor should not be difficult to figure out. Get a quote or all that may end up costing you several hundred dollars that you may not have been expecting.
I made the mistake of takin' my BMW to the dealer once. I got a quote for a timing belt install & valve adjustments. They performed all kinds of extra work - including oil seals. All the extra stuff would have cost me another $900, but because I had a quote and they did not have the authorization to do additional work, I got all the extra stuff for free. I did offer to pay for the parts & finally did just that.
Posts: 2,163 |
how much do you guys think it would it cost to have the ford dealer perform the Intake (upper/lower) system rebuild found in the faq
Posts: 2,725 |
Originally posted by TourDeForce:
Pep boys does a TB cleaning for around $80. They pull the TB & scrape out the EGR passages like our typical TB cleaning How-To. I don't trust Pep-Boys any more, not even for tires, so I do all this myself.
I dont trust those morons either took them five times to finally fix my serpentine belt so it wouldnt squeal anymore.
Posts: 2,163 |
If I were to have ford perform the Intake (upper/lower) system rebuild found in the FAQ should I let them know before I take the car in to have this work done and so must have them order these parts before hand or can I assume that they will have these parts in stock. My service appointmentis one week away so maybe I should call them back and speak to the service writer guy and possibly email them the FAQ notifying them what parts are necessary
Within an earily post I stated that FOrd offers an Emissions tec for 119. thinking that all of this work would be included but after adding up the cost for these parts minus the PCV and determining there price to be a minimum of $239.31 I would have to say that I made a wrong assumption.
Upper intake manifold gasket P/N F5RZ-9H486-B (1 set) ~US $18
Injector nose O-rings F0PZ-9229-A (pkg of 10) US $7.57 (1995-97 only)
Upper injector O-rings F5RZ-9229-AB (comes in a pkg of 6, but you are charged for each) US $17.16 (1995-97 only)
Lower intake manifold gasket F5RZ-9439-B (1 set) US $18.10
Fuel rail to lower intake manifold seals F5RZ-9P867-A (you need 6) US $13.32 for 6 (1995-97 only)
Fuel pressure regulator F4SZ-9C968-A US $41.81
IMRC linkage grommets (3 for 1995-97, 2 for 1998+) F5RZ-9F955-AB ~US $15
UIM Plastic Retainer Grommet with brass insert sleeve F5RZ-2A411-A ~US $8-10
Throttle body gasket F5DZ-9E936-AE ~US $1.95
EGR gasket E6AZ-9D476-B US $1.35
IAC gasket E83Z-9F670-A ~US <$1
parts total 239.31
Posts: 1,246 |
Order the parts from Bill Jenkins. He quoted me prices less than that.
Posts: 2,163 |
will be going to the ford dealer tomorrow to arrange to order the parts for the intake overhall FAQ because it is assumed that since this car is a 95 the parts will not be in the shop.
Posts: 610 |
These are the last things I [censored] need, and I was just quoted at one (of 2 dealerships in all of the chicago area carrying it) dealership for $9.00 A PIECE! That 9 x 6 = $54.00!!! Theres more rubber on a condom, how could they charge so much?!
2001 BMW 325i Sport, Stickshift
'96 Mercury Mystique V6 *TOTALLED*
For sale:
Alpine CDA-9811
Eclipse Amplifier
Pioneer Tweeters
