#88794 04/06/02 01:49 AM
H
hmouta Offline OP
H
so i got the crutchfield amp bypass kit and the metra kit to put the oem tape player back in the 95 gl. This shouldn't be a problem. i'm putting the jensen hu from the 95 into the svt.
do u guys have any tips or things i should look out for? i have the intructions from crutchfield. is it basically following them. the bypass harness has a ton of wiring. will i need it all. can i snip some of it off? i'm doing this tomorrow (saturday).
if going to be putting in the dash clock while i'm messing w/ the wiring and radio.
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
#88795 04/06/02 02:02 AM
they must give you a mile of wire...no you probably only need 3 feet of it and that's being generous. The excess does come in handy for other do it yourself projects though.
1999 Silver Frost SVT
#609 of 2760
Born on 12/3/98
KKM Intake
Removed Resonator
35% Window Tint all around
Tinted Tail Lights
ElKy Mesh Grilles
HID
Dyno'ed at 175.3HP/155.5TQ
#88796 04/06/02 05:38 PM
How much WAS THAT AMP By-Pass kit for your contour.
Big Pimpin' 96 Contour SE.
2.5L V-6, 24VL DOHC, 5-speed
Phat System pushing
2 12" JL Audio W0
Pushing around 175hp right now at crank
purple neons under dash
APC fog lights with hyper white bulbs
Hyper white headlight bulbs
K&N air filter
#88797 04/06/02 05:48 PM
I paid $20 + $4.95 for S/H when I ordered it a while back. It included all of the necessary wiring harnesses for installing your stereo, the amp bypass harness, radio removal tools, and detailed instructions for everything stereo related (HU, amp bypass, antenna replacement, speaker replacement front/rear).
1999 SVT #900/2760
Born on 1-20-99
Silver Frost/Midnight Blue
A few aesthetic and audio mods
#88798 04/07/02 12:38 AM
H
hmouta Offline OP
H
mine was about 22 w/ shipping. i didn't need the hu removal tool (already had one)
AIM:omegazodiac
95 gl
built 4/6/99
black/tan
Moderated by  dnewma04_dup1
