Has anyone ever thought to wire their headlights so the high beams come on at quarter power when the lows are on? I've seen this on other cars, but i cant remember which ones at the moment. And when the high beams are needed they will come on full power. I assume it wouldn't be too hard to do, a couple of resistors and a diode. May sound silly but Im interested in what you all think.
ok, nevermind...
$30.00 for the stock DRL relay from your Ford Dealer. Just unplug the bar, plug in the relay and your good to go.
$25.00 from me shipped and I'll even walk you through it.
www.ChicagoCEG.com 2006 White Grand Prix
W
W
I want to do this too, sounds cool. I could add another switch to the car then!
1999 Contour SE Duratec ATX My feet and the Stra�Ÿenbahn http://www.tempo-topaz-performance.com/topazsho/ the coolest Topaz ever! To bad it's not mine
im not clear, the stock drl relay will do what i explained above or run it at full power?
I don't think, if you consider this logically, that you are actually needing to ask this question..
Ask yourself this: Do you currently have the daytime running light relay (DRL)?
If yes: no need to ask
If no: Can you currently turn your headlights on full power high?
If no: see haynes manual for repairs.
Ray
