Ok, today is my first of many mod days this week while I'm out of school. Each scene is followed by a question or two. I will list all of my wounds at the end of the post for everyone's enjoyment.
Scene 1: I've got CEL code P0430-front cylinder bank pre-cat belown optimum threshold. To fix this, I swapped the upper O2 sensor with one that was in a set of used exhaust manifolds. I did the upper sensor because
after a search, I came to the conclusion that the general cause of this code is the upper sensor instead of the lower. The used one I put in is from an SVT and it looked different than mine. The SVT O2 sensor sticks out into the exhaust manifold just as far, but it has many more pores in the protrusion. So that was confusing, but I clipped the wires and soldered the new (SVT used) O2 sensor to my old harness.
Question 1) Why are there two identical white wires on the O2 sensor? Since they're the same color, does it matter if you mix them up when installing a new sensor?
Scene 2: My car has 68k miles and has yet to have the UIM/LIM/TB cleaned. So, I started to do that. Crap I didn't know there were so many damn different sized bolts all around the UIM!! Anyway, the vacuum hoses on the top of the UIM, right after the TB, they don't come off easy. I broke the longer one closest to the TB. I am going to break it off at the other end and take it to Ford to see if they have one in stock. Otherwise, I'll order one from one of the online parts stores.
Question 2) What is this vacuum hose? Where does it go? What does it do?
Question 3) What's the easiest way to remove the vacuum hoses without breaking them?
Scene 3: Car has 68k and stock plugs. I put on new plug wires about 4-5 months ago and they fixed whatever problem I was having and can't remember right now. I pulled off the IMRC cover and the IMRC. I started with #6 and when I got the old plug out, it looks completely different from the new plugs I got from SP Motorsports.
Old plug facts:
Motorcraft Platinum
AWSF 32F Edit-this is the listed model # on SP's page
has ~1/2 of threaded area as the new plug that screws into head
New plug facts:
Motorcraft Platinum
AGSP 32FM Edit-I can't find this number anywhere for another vehicle
Has twice as much threaded area as the old plug
The problem is, the new plug seems to be bigger in diameter than the old plug, so it won't screw into the head. I tried putting the old plug back in and it bit right into the head and was getting tight right away. The new plug will just sit and spin on the opening. I help them up right next to each other and the new plug really does seem bigger.
Question 4) What is the difference between AWSF 32F and AGSP 32FM? And which should I have?
Wound #1: while using a flat head screw driver to try to pry off the vacuum hoses (scene 1); it slipped and took a decent chunk out of very end of my left thumb. It is still bleeding, but I put a band aid over it and taped it up tight with electrical tape so it won't come off. It hurts like a basid because of all the grease and whatnot that was already all over my hands.
Finally, I have a second vehicle so don't worry about me drivin around with a broke vacuum hose. I'll beat around in our 92 Ranger.
