Originally posted by YoungGun:
Ok so I have decided to get two PB 12's (with the DVC option), I don't know much at all about enclosures or different boxes so what else do I need to get? Should I get one of the $60 Passive Radiators that stryke suggests (I don't even know what a passive radiator is)? Basically I want to get everything I need so when I take it to be installed, they won't just tell me I still need to go buy more stuff. Thanks.
I don't think you will have any use for the DVC option. So save yourself the 60.00. The passive radiator is basically an alternative to a port. Since you are going with a sealed enclosure, it isn't necessary.
You will need a 1.5-2.0 cubic ft sealed box. That is for both (.75-1.00 cu ft per woofer). Are you going to build your own or buy a premade enclosure?
