Page 3 of 4 1 2 3 4
About 700 on Tru Duals
CTA intake was about 120 I think
98 Lime Green SE w/SVT Kit, Projectors, CF Hood, 18" Rims, GC's, Shaved, System 98.5 Silver SVT #5737 Black FSVT Rims, MSDS, BAT Drop 85 Toyota PU Lifted 06 GSX R 600 Black/Silver My Rides
Alright, here come the BIG GUNS:
TH fix: $0.68.
Now, if we included maintence costs only, I would be WAY up there. two entire engines, with labor, one new clutch: $2600.
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
Hmmm....
Engine/Induction/Exhaust
$ 55 Optimized TB (not counting core charge and powder coating)
$ 45 9 mm FMS ignition wires
$ 120 Brad Noon custom 3" intake pipe
$ 35 S&B 8", open cone filter
$ 20 MAF Adapter
$ 595 MSDS Headers and Y-Pipe
Transmission/Driveline
$1150 Spec Stage II Clutch, Flywheel and Torsen LSD
$ 30 Redline MTL
$ 105 Steeda Short shifter and riser plate
Wheels/Suspension/Brakes
$ 290 Approximate cost Stazi's brake pads and rotors (4 sets)
$1000 Rev Model X (17x7) w/ Toyo Proxes 215/40/17
$ 400 Rousch Cougar springs and ST200 struts
$ 60 Steel brake lines and synthetic brake fluid
Total: $3,905 Without labor, and not counting aesthetic mods, like tinting, plate frame, dead pedal, etc. And a PnP is still coming, as well as a superchip sooner or later.
99 E1 SVT Black/Tan, MSDS Headers, SHO-Shop Y, BAT Intake, Opt. TB, UR Clutch/Flywheel, Quaife, B&M, Konis, GC Coilovers, Pulley, Mintex Pads, 17" MAS Italy Rogers, Nitto 215/45/17, Portmatch, 138K
I
I
wooo
tuning is expensive
SCA intake + K&N - 125
off road sho shop y-pipe - 165 (i think)
FMS wires 40
trubendz cat-back - 340
FORSALE - 17" FSVT Wheels, TRubendz catback w/magnaflow muffler PM ME 02 celica GT-S 6-spd w/ TRD bodykit Greddy evoII exhaust, DC sports header Injen Short ram intake, TWM short throw shifter, 18"centerline storm wheels, Tein basic coilovers
Originally posted by ContourKev:
I wish I had money like that....
99 Blk SE Sport 2.5 CD4E Euro Focus SVT Wheels 5 % tint Mesh Grilles w/indiglo ford KKM intake filter FMS 9mm wires Superchip Signal mirrors Fog lamp mod Dingless A6 sidemarkers Duals SVT springs/struts
I have the same motor as Burrita. I just don't quite have all the little parts yet. I think he has me by about $1000-1500 or so.
Edit: After reviewing Joey's list he has a few more things than I do. He has me by about 3-4k.
2001 Lincoln LS8 1994 Lexus GS300
$3500 for a blown engine and it looks like another one is blown. Guess what?? I ain't paying [censored] this time. [censored] Ford.
Now I hate America? That is a new one to me.
OOps I forgot my walbro 225 lph fuel pump $125.00
99 SVT #198 blk/blue Spec 3/quaife/stage 2 shafts T3/T4 fully built 3.0 ported heads water injec./intercooled 13.2 @ 107 mph clifford alarm and turbo timer koni struts H&R springs intercooler for sale
Learned patience the hard way
Suspension Modifications
Koni Adjustable Struts
Eibach Lowering Springs front
H&R Lowering Springs rear
24 MM Aussie Bar- Rear Sway Bar
¼ Metal sway bar backing plates
Poly end link bushings
ES Motor Mount Insert
245/45/16 Yoko AVS Tires
5 MM spacers at rear wheels
Tubular Steel Adjustable Rear track arms
From Buckshot Motorsports
Energy Suspension Rear Control Arm, Front and Rear Sway Bar bushings
12.2? Superlite Brake kit from TCE Performance
11.25? Upgraded Rear Brake Kit from TCE Performance
Cryo Treated Brake rotors by 300 Below Inc.
Drivetrain & Performance Modifications
BNM prepped 3 liter block
SVT Cams, w/ water pump drive removed
Cunningham Chrome Molly Rods with upgraded rod bolts
Clevite 77 rod & federal mogul main bearings
Dual Mode Mondeo Damper
SHO Shop lightened Billet Flywheel
Crank Knife Edged and motor balanced by Horn Race Engines
Pistons, crank, and rods cryo treated by 300 Below Inc.
3 Liter Heads Port & Polished with multi-angle valve job by BNM
Port matched UIM and LIM
RAM Clutches Kevlar Pucked clutch and HD pressure plate
2000 Model Year Transmission
HMS Inc. Mark III transmission update w/ full lube system & Zetec Final Drive Ratio
Quaife LSD installed by HMS Inc
Driveshaft Shop level III CV shafts
Cryo treated wheel hubs and studs
42 lb Ford Racing Injectors
MSD DIS-4 ignition Control
Water Injection Kit
Accusump 2 qt accumulator
Remote mount oil filter
Apex-I SAFC
Ford 9MM Plug Wires
B & M short Shifter
75 MM Pro-Flow MAF
65 MM Throttle Body
2.5? True Dual Exhaust w/ Magnaflow race series mufflers and crossover
Custom 1.75? Nickel Plated headers by MSDS Inc
Vortech Supercharger w/ upgraded shaft and 2.87? pulley
Custom water to air intercooler by Buckshot Motorsports
Autometer Phantom gauges including A/F Ratio, Oil Pressure, Oil Temp, and 5? monster tach w/shift light.
4 point Safety Harness
Dual Honed SVT upper intake
Trunk mounted battery
Aesthetic Modifications
BNM Polished stainless sill protectors
Removed door ding guards
Foglights run w/o head lights
BNM Indiglo Gauges & HVAC Panel
Powdercoating of Various engine pieces by BNM
Billet Pedal Kit including dead pedal
15% window tint
Body color matched grilles at all locations
Painted SVT Emblem at hood grille
Custom Front Fender Badging
SSR GT1 series 16? Rims
PIAA 510 Driving Lights
Front Splitter by Mirko Racing
Sponsors
Brad Noon Motorsports
Cunningham Rods
MSDS Inc.
RAM Clutches
TCE Performance
300 Below Inc.
Wolfe??s Auto Body
I haven't updated it for a while but currently the price just in mods not including any labor is $24,000
Come on who here can give me a run?!
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180 Buckshot77@msn.com Misc 3L parts for sale
Page 3 of 4 1 2 3 4
