Posts: 146 |
So which sub is better (10" size), the Eclipse Titaniums or the Polk/MOMO's? What are the differences? (And by the way, what does SPL mean as opposed to SQ?) Appreciate any info you crazy guys can give me, thanks.
1998 black Contour SVT E0 -KKM Intake -Magnecor 8.5 mm spark plug wires -Bosch +4 platinum spark plugs -B&M Short Shifter -SPARCO front strut tower bar -17x7 Rage 5.0's with Nitto NT450's (215/45-17) -24mm Aussie rear sway bar
Posts: 8,142 |
Originally posted by YoungGun: So which sub is better (10" size), the Eclipse Titaniums or the Polk/MOMO's? What are the differences? (And by the way, what does SPL mean as opposed to SQ?) Appreciate any info you crazy guys can give me, thanks. There is no comparison. The Titanium is superior by a large margin in every respect. Aesthetics are the only think the MOMO can hold it's own in. SPL refers to Sound Pressure Level. If loud is your goal, it is generally referred to as an SPL install. SQ stands for sound quality. Both of these options are subs that are overpriced if that means anything.
Posts: 146 |
hmm, what's the lowest you think I could get them for?
Posts: 8,142 |
Originally posted by YoungGun: hmm, what's the lowest you think I could get them for? Good question. The Eclipse would probably cost you ~400-500.00 each. The Momo mid 200 hundred range. I'll check around for you.
Posts: 146 |
How does $300 each sound for the 10incher titanium eclipse sub?  (forget the momo's!)
Posts: 8,142 |
Originally posted by YoungGun: How does $300 each sound for the 10incher titanium eclipse sub? (forget the momo's!)Sounds pretty good. They are definitely the Ti's and not the aluminums, right? Best price I found was 524.00.
Posts: 146 |
Yeah defenitely, I couldn't believe I found it, but the part number and everything is correct. pretty kick ass eh? I was figurin on running a 1000.2 Rockford F. amp to two of them. 500 a piece, would that be good enough?
Posts: 8,142 |
Originally posted by YoungGun: Yeah defenitely, I couldn't believe I found it, but the part number and everything is correct. pretty kick ass eh? I was figurin on running a 1000.2 Rockford F. amp to two of them. 500 a piece, would that be good enough? Definitely enough power. They can handle twice that in case you wanted to upgrade in the future. Where may I ask did you find this deal?
Posts: 146 |
You may ask, it infact was at a website called: www.audiomyth.com Not sure about their credentials or anything although I see no reason not to trust them. They're just not as big as etronics or somewhere else like that. Etronics is also very good by the way if you have heard of them (etronics.com). Will I need a capacitor for this as well? P.S. When you go to audiomyth.com., you have to type in eclipse in the search, I couldn't find any other way to access them.
Posts: 370 |
I found that sight the other day. Some of their prices are unbelievable. I wonder what their history on business is like tho. (slow, fast, poor customer assistnace, etc) Anyways good website in my opinion.
Chris Bertrand , !!16 years young !! 1995 Ford Contour Gl 2.5 V6 MTX My DIMS (DO IT MYSELF) Achievements: Performance Mods: None Audio Mods:Jvc head unit, 6x9's in all doors , Sony XM-752EQX amp, 2 Sony Xplod LS-1235 12" Subs Video Mods:Blaupunkt DVD-ME1, 2 5" monitors in sunvisors Aesthetic Mods:Neons, Streetglow El Shift Knob Commando LCD Pager Alarm Many Mods To Come.......
