Posts: 104 |
Hey guys, I installed a complete SVT intake assembly on my 98 SE V6 over the summer. When I first start the car, it revs up to about 2000 RPMs and then eventually goes down to a normal idle speed. I replaced everything from the fender well to the TB with the SVT setup except the IAT sensor. I just soldered on some longer wire and plugged it into the rubber hose between the TB and the MAF. Should I purchase the IAT sensor for the SVT or is the SE one sufficient (are they even different)? Would this even correct the problem I'm having or is it something else (the PCM)? Thanks for your help in advance!
1997 Contour Sport ATX
Zetec/2.0 liter
1998 Contour SE ATX
Duratec/2.5 liter
Posts: 1,145 |
the SVT has no IAT so good luck buying that, also did you reset the PCM after you installed it, if you didnt need to do that lemme know if that helps
98.5 Black SE ATX
Posts: 4,714 |
This is normal operation. My Sport revs up to 1500 and my SVT revs up to 2000. As long as it starts to drop down to 1000 within a few seconds I don't think anything's wrong. Still, as mentioned, it wouldn't hurt to reset your PCM if you haven't done that already.
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 1,145 |
i was gonna add that but decided not to just incase he had not reset his pcm and thought he did not need to because it was ok
98.5 Black SE ATX
Posts: 104 |
I reset the PCM by pulling the two fuses (#4 & #11) back when I installed the system. It revs high on start up and then kicks down after about 5-10 seconds. As far as the IAT sensor goes, there was an opening for one in the accordian tubing from the SVT so I don't know why the SVT wouldn't have one. FordParts.com lists a different one for the SE vs. SVT so I'm not sure what's the deal with that. Anyone here upgrade their SE intake to the SVT intake and get another sensor? Thanks again for your help, I appreciate it.
Zetec/2.0 liter
1998 Contour SE ATX
Duratec/2.5 liter
Posts: 496 |
I bought a new SVT accordian hose, when I converted, and it came with the IAT sensor installed in it. That piece of rubber cost over $85, I'm glad the IAT was part of the assy.
Posts: 104 |
Could you give me a part number for the sensor itself so I can cross-reference it with the one on my 98 SE to see if they are the same thing? Thanks!
Zetec/2.0 liter
1998 Contour SE ATX
Duratec/2.5 liter
Webmaster
Webmaster
Posts: 1,359 |
Originally posted by gearhead98: the SVT has no IAT so good luck buying that, also did you reset the PCM after you installed it, if you didnt need to do that lemme know if that helps
Misinformation, the SVT certainly does have an IAT! It is in the accordian tube!
-Lance
Lance Kinley
CEG Webmaster
95 SE, "Cassandra"
10 years!
Posts: 104 |
Thank you Lance, I knew I wasn't imagining it. Anyone have a part number I can use or is the IAT sensor not even the cause of my problem? Thanks.
Zetec/2.0 liter
1998 Contour SE ATX
Duratec/2.5 liter
