Posts: 375 |
does anyone think that i will have any problems running 225/45 18's on my Superleggeras with a stock SVT suspension, or would it be better to go with 225/40 18's? i belive that they are 18x7's also if i were to go to the H&R springs would i run into problems?
Thanks
Alex T.
98.5 Silver Frost CSVT #5510
05 Nissan Frontier Nismo 4x4 6 speed
85 Bronco II 6" lift 302 swap
Posts: 148 |
All i can say is I have not had a problem with my setup before or after the suspension change.
18x7 with 42mm offset
225/40 tires i think, if its different ill let you know
H&R spring
I was concerned about rubbing but it hasnt been a problem. I have about a finger tip of space between the tire and strut and it seems to be enough. I asked a million and one question before i did this some reported problems and others didnt. I think its the ways our cars are made that day as to whether youll have a problem or not. since the 45 series tires are a lil wider you maybe pushing the envelop, so i would play it safe with the 40s.
BTW im jealous of your superleggras.
Posts: 148 |
Originally posted by pupet89440: All i can say is I have not had a problem with my setup before or after the suspension change. 18x7 with 42mm offset 225/40 tires i think, if its different ill let you know H&R spring
correction, I said that wrong....45 series are a lil taller. You may have a lil problem when turning with those. Anything wider you could have a problem with strut clearance
Posts: 375 |
thanks for the reply.
oh and thanks for the compliment on the super's, i bought them off a focus guy and the tires are just way too low-pro for my liking.
Alex T.
Posts: 266 |
Be careful of that 18x7 as the 7" width is too small for most of the 225 tires. They like to see a 7.5 or 8.0" rim.. Too wide a tire will lead to premature tire failure..
Posts: 2,446 |
many people run 225 on stock svt and non svt rims, i believe both are 6.5"'s wide. i ran 225's on mine with no problems at all.
Posts: 349 |
Posts: 1,785 |
Originally posted by brian8064: go 225/40/18...
What he said. I run that size tire on a 7.5 inch rim.
Just a Plain SE.
AKA Big Country
I maybe path914's B**** now, but wait until he needs his clutch done. We will see WHO is WHO's B**** then!
Posts: 2,369 |
I got three 215/35/18s if you are interested. Really cheap since I dont need them anymore.
98 Lime Green SE w/SVT Kit, Projectors, CF Hood, 18" Rims, GC's, Shaved, System
98.5 Silver SVT #5737 Black FSVT Rims, MSDS, BAT Drop
85 Toyota PU Lifted
06 GSX R 600 Black/Silver
My Rides
Posts: 202 |
I have 225/35/19's and Koni/Eibach suspension.....I haven't rubbed once, ANYWHERE!!!! PM me if you have any more questions.
#1000 of 2760
Money talks, it says good-bye!!!
19's are here...
