#880314 02/23/04 03:05 AM
Should be receiving my Re-enforced Subframe from TH this week and I was curious if there was anything to replacing the subframe? I did a search and didnt' come up with any specifics on how to install it. I'm assuming that its just a few bolts to remove the orig. and replace right?
Any tips would be great.
Thanks for the help!
2001.5 S4 Santorin/Silver Stock...For now!
#880315 02/23/04 10:22 AM
remove exhaust, remove struts/knuckles, remove the 4 bolts that hold it in. Put a jack under it so it doesn't fall on your head It's not that bad of a job. Remove the control arms after you get the old subframe out. I found it easier to loosen the bolts that way. And make sure when you reassemble it that you leave the control arm bolts loose. You have to have the car on the ground to torque the control arm bolts
06 GMC Sierra 2500HD Dmax/ally 06 Pontiac G6 GT 05 CRF250R FOR SALE 06 KX65 with riding gear $2700 obo
