I just got a CDW-27 Essential Tool kit off of Ebay for $75. It not only includes the subframe alignment pins, but also the CONNECTING ROD GUIDES, CAMSHAFT SEAL PROTECTOR, CAMSHAFT SEAL REPLACER, CAMSHAFT DAMPER REPLACER, WATER PUMP PULLEY REMOVER, WATER INLET TUBE REPLACER, VALVE GUIDE REPLACER, VALVE SPRING COMPRESSOR, VALVE STEM SEAL REPLACER, CAMSHAFT ALIGNMENT TOOL, VALVE STEM SEAL REMOVER, VALVE GUIDE REPLACER ADAPTER, VALVE SPRING COMPESSOR ADAPTER, MEASURING FIXTURE, SHIM SELECTION TOOL, BEARING CUP REPLACER, DIFF. DRIVE SHAFT SEAL TOOL, SELECTOR SHAFT BEARING TOOL, PINION SPLINE SOCKET, GEAR LEVER ALIGNING TOOL, DIFF. BEARING CONE TOOL, SELECTOR SHAFT SEAL TOOL, POWERTRAIN ALIGNMENT GUAGE, TRANS. RANGE SENSOR TOOL AND THE SERVO PLUG REPLACER
