Posts: 4 |
Hey Guys, My check engine light has been on for a while. I replaced wires plugs air filter and O2 sensor. I took it to autozone and they said Bank 1 lean.
what could it be? They sold me a O2 sensor but it did not do the trick. The car starts rough at first but then does fine. The problem is when I stomp on the gas, it does not pick up well after about 35000 rpm.
Posts: 2,408 |
Welcome to CEG!
Year? Miles?
Did you replace the O2 on the exhaust manifold by the radiator? If so, clean your MAF and/or look for vacuum leaks. Replace the PCV valve and short rubber hose under the exhaust manifold.
Lack of power above 3500 RPM could well be a sign of a clogged catalytic converter or a crushed exhaust pipe.
Posts: 270 |
Welcome to CEG. the v6 in the contour is a Duratec not a zetec. YOu may want to change your title so you get more replys
99 Se,MTX,TS.
Koni,Eibach,SVT Plastic,tunes,Opt Y-Pipe, Elky mesh, DMD, SVT BRAKING, Eo's, 95 Leather int.
Posts: 2,127 |
Originally posted by REDSPOT321: Hey Guys, My check engine light has been on for a while. I replaced wires plugs air filter and O2 sensor. I took it to autozone and they said Bank 1 lean.
I wanna know how you get it to 35000 RPM. Doesn't it sound a lot like a jet at those speeds?
j/k
TB
"Seems like our society is more interested in turning each successive generation into cookie-cutter wankers than anything else." -- Jato 8/24/2004
Posts: 21,653 |
Originally posted by TBNPLR: Welcome to CEG. the v6 in the contour is a Duratec not a zetec. YOu may want to change your title so you get more replys
Who said it's a v6?
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 270 |
Originally posted by TBNPLR: -------------------------------------------------------------------------------- Welcome to CEG. the v6 in the contour is a Duratec not a zetec. YOu may want to change your title so you get more replys
Who said it's a v6?
Correct me if I'm wrong, but how does an inline 4 have more than 1 Bank of cylinders?
99 Se,MTX,TS.
Posts: 2,127 |
Who said it's a v6?
It's not that the 4 has more than one bank of cylinders, but that OBD-II has a fixed set of codes, so OBD-II does refer to different banks.
So you will get "Bank 1" codes on a Zetec, you just shouldn't/wouldn't see the bank two codes.
The codes are set by the Federal Government and are used by all cars sold in the USA regardless of how many banks.
I wonder what codes you get for the VW "W" style engines or a rotary engine in a Mazda RX8?
Hmmm,
TB
Posts: 270 |
This is helpful and logical.
thanks.
99 Se,MTX,TS.
Posts: 21,653 |
Who said it's a v6?
Hmmm,
TB
If I were one of those companies, I'd do the mandated codes but with supplementary codes to specify the exact thing.
98.5 SVT
Posts: 328 |
When the Mystique was showing a CEL my code reader refered to Bank One running lean. I replaced both O2 sensors, and still had the problem. I would reset the light each time, but it would still come on during heavy acceleration. I tried cleaning the MAF but no difference. Finally went to the dealer who replaced the MAF and it's been fine since.
- Jim
Our yardbirds:
Belvedere, our '96 Jeep Cherokee, 4.0L ATX, 85,000 and going strong
Spencer, our '03 Chrysler PT Crusier, 2.4L ATX, 28,000 and just getting started
