#879021 02/21/04 02:12 PM
9
9
When I hit my horn, the pitch waivers quite a bit, plus our horns do not have a tendancy to demand much attention, so I am looking to replace my horn with an aftermarket horn. I have the 98 Ford CD, but it is really no help. When I bring up the horn installation/removal, it lists 3 horns. "Horn", "Horn with speed control", "Horn without speed control" and the "Horn" one looks pretty easy, except I can't really figure out where exactly that the horn is, but the "Horn with speed control" is talking about removing plates, screws, springs, and all kinds of stuff. Can anyone help me out? Thanks! -Spencer
Aiwa flip down head unit Pioneer 6x8 3-ways all around Two Polk/Momo 10" subs pushed by a bazooka amp Custom grille Silverstar high/low beams Autolite 8mm plug wires
#879022 02/21/04 02:18 PM
the horn if it is the same on a msytique is behind the front bumper somewhere, you should be able to find it if you know what you are looking for
hope that helps
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
#879023 02/21/04 02:19 PM
Replace the horn itself (under the hood).
For help in finding it, have someone press the horn pad while you have your head under the hood. You will find it very quickly.
See section 413-06, Horn, Removal and Installation for exact procedure.
Steve
#879024 02/21/04 02:43 PM
W
W
Mine is behind the front bumper, down on the left, I think. It's up inside the bumper. Good luck!
WA 2 TUFF SVT 2000 Tropic Green SVT Born 1/28/2000-1975 out of 2150-only 207 made. Some new pics
#879025 02/21/04 02:51 PM
H
H
Horns are at front left/right of car, behind bumper but in front of wheelwell. You have to remove the lower underside stone guard to see and gain access from below. Some models (including your's) came with only one horn but wiring should be in place to add the 2nd if desired.
#879026 02/21/04 03:17 PM
9
9
Thank you all! That helps a lot!! I'm going to try to get in there today and take a look around, by the way... does anyone know much about aftermarket horns? fitment, sound, etc? I was just going to go to the auto parts store and buy whatever looked like it would fit and work, but I guess that's not a very smart idea. -Spencer
#879027 02/21/04 06:45 PM
if you want a good horn, go to junk yard and get one off a 70 year ford, or early 90's ford.. i got a 93 taurus and the horn on it is alot louder than what came with our
96 contour..... and you can adjust the screw on the horn to get the pitch that you want.. and when it is correct you just paint some ladies fingernail polish on the screw so it does not move and go off the pitch you want...
on a contor you gotta take off the plastic shield under the fornt of the car to get to it.... hope this helps.
#879028 02/21/04 09:49 PM
H
H
Get this horn from Pep Boys called "Freeway Blaster". Let me tell ya what, people get the [censored] scared right out of them, when you press hard.
#879029 02/22/04 04:40 AM
9
9
I bought a horn at pep boys, that claimed to sound like a "big rig horn... twice as loud" and it looks almost exactly like our stock horn... I installed it and it is a lot higher pitch than our stock horn. I am definitely not happy with that. I am taking it off tomorrow and installing an old modified "aooga" horn that is uncomfortable to listen to because it's so loud. BTW, it does not make the old "aooga" noise... just a really loud, low blast. Thanks for the help anyways everyone!
#879030 07/10/04 06:24 PM
Forget that,
Do what I did, go to an auto parts store and buy an air horn. It sure gets people out of your way!
