Posts: 219 |
Hello audio fanatics,
I was wondering what springs you all are using with a heavy trunk setup ~~ 75-100 Lbs. My Eibach seup will probably rub when I get new wheels of they are any wider than my 99 Se sport wheels. What about using stock springs or H&R? Some pics would be most appriciated.
Thank You,
Chris
99 Se,MTX,TS. Formerly Dieter88, TbnPlr NEW ding guards !!
Posts: 1,592 |
I have quite a bit of wieght in my trunk. I'm running Eibachs and Koni's. I also have oversized tires. 225-50-16. I have no rubbing issues. Mind you these Konis are stiff though. I bet with stock struts there would be rubbing.
Posts: 325 |
75 to 100 lbs. shouldn't create a problem.
1999 Silver Frost Contour SVT 2690 of 2760 Born 08/13/1999 Sony Mobile ES CDX-C90 Deck 6 1/2 Infinity Kappa Perfect mid & tweet set, 2 12" Infinity Kappa Perfects JBL P.600.1 for Bass, P.180.2 for front stage.
Posts: 219 |
Hey thanks for the replys,
My rears are tucking right now and if I go with bigger wheel tire combo I'm concearned of a problem occouring. what offset wheels are you guys using?
thanks,
Chris
Posts: 470 |
I've got an enclosure/setup at about 200lbs+ in my trunk. I've also got eibachs, and stock struts (no money to change yet.. lol), but no problems. So i doubt that 75lbs would cause some trouble for you.
Give me more beer and CEG before i get depressed!
AIM/AOL: DBZ Jr
Posts: 219 |
DBZ,
What type of wheel ar you running?
Chris.
Posts: 470 |
I've got stocks, but i will be doing an upgrade. But i'm sure it won't matter too much, because i tend to have "LARGE" passengers sometimes in the back. But i'm pretty sure it won't be that bad for you.
AIM/AOL: DBZ Jr
