Posts: 205 |
Anyone know how to adjust these? Car wont shift into gear when cold in the morning...nver used to do this...and the fluid is new also.
Posts: 3,290 |
AFAIK, you can only adjust the neutral position. I've posted a few times trying to find out how to adjust the throw/play, but never got any responses. There's nothing in the service manual either AFAIK.
E0 #36
'95 Ranger
'82 Honda CX500
Posts: 205 |
thanks for the reply. After 40 views I thought at least someone would reply, considering the gods of ceg can build engines, push out big power, and talk about all of the intricate details of the contour.
Posts: 4,714 |
I'm definitely not one of the 'gods' of the MTX-75, but I can say this sounds like typical synchro wear; not something that can be fixed by adjusting your shifter. Also, this question probably would have gotten a better reponse from the Transaxle forum. There is currently a discussion about "hard-shifting when cold" going on right now, as there almost always is at any given time.
EDIT: here's a Link
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 1,049 |
i iwsh i could adjust teh cable i have a bit of play on the lever front to back it seemed a bit more when the dealer put in new gear changer that goes on top of the tranny.
Posts: 4,140 |
what fluid? that could easily be it. try running through the gears as the cars warms up (while sitting still)
Posts: 205 |
Thanks for the replies...mobil 1 cocktail...brand new...I actually start it up and put it in first...if I dont it wont go into any gear.
Posts: 4,140 |
Yeah, search for fluid cold shifting or something and you will find a lot on how the "mod" fluids do in cold weather... the reason i'm not putting in redline until spring
Posts: 21,653 |
Digging up old thread...
So is there a way to adjust cables? With the Ford CDs, it says go to section ..... and I can't find anything about adjusting in that section. Just wondering if I replace the cable end, does it need adjusting afterward?
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 5,345 |
1996 V6 ATX 96K miles
