#87760 03/15/02 04:36 PM
BIGS Offline OP
im trying to run my interiors with my amp which is in the trunk, but theres no sound(problem).i have all the speaker cables and the RCA's running to the amp. I set my line in switch on the HU which is for external amps and my stock ones work when i set the line out switch for an internal amp no speakers work, i have my new ones with all the connections in the front and stock in back.is there a factory amp in my car?wiil that effect it?i have a 98 csvt.
98 SVT
MODS:
Something or another
#87761 03/15/02 04:43 PM
This may sounds silly but did you run speaker wire from the amp to each speaker?
-Colter
My Car
#87762 03/15/02 04:50 PM
yes there is a factory amp.
it's located behind the glovebox.
if you go to any audio shop the should
have an amp bypass harness that can be
sacraficed to make the wireing really
easy. much easier than running wires
to every speaker laugh
'98 E0 T-RED CONTOUR SVT
#558/6535
Got Tunes:
Sony CDXC-90, CDXT-65, XDP210EQ
MCINTOSH MC4000M
BOSTON PRO 6.5 COMPONENTS
BOSTON PRO 12.5 LF
POLK DB4500
STINGER 1FARAD CAP
RED NEON INSIDE AND UNDER
THROTLE HANG FIX
RESONATOR REMOVED
#87763 03/15/02 04:52 PM
BIGS Offline OP
yessss, ive done this before, just not with these components.i even ran the speakers directly from the amp, cause im running them through the crossover, and no go, so its either the HU or the AMP not giving the signal.
98 SVT
MODS:
#87764 03/15/02 04:56 PM
BIGS Offline OP
to every speaker
So im thinking i have to disconnect the factory one, its causing an interference.
98 SVT
MODS:
#87765 03/15/02 10:24 PM
Teh factory amp needs to be bypassed.
It can't accept the input voltage from
your other amp. Go to a good audio shop
and tell them you have a ford premium sound
package and that you need th amp bypass
harness. It hook the input into the factory
amp to the output to the speakers. That way
you use the wires behind your HU and it goes
to your speakers.
#558/6535
Got Tunes:
MCINTOSH MC4000M
BOSTON PRO 12.5 LF
POLK DB4500
STINGER 1FARAD CAP
THROTLE HANG FIX
RESONATOR REMOVED
#87766 03/23/02 03:48 AM
I had a similar problem. Come to find out it was the turn on signal from the factory radio to the factory amp. The signal was not strong enough to turn on my Presion Power amp and the factory amp at the sametime. To solve the problem I used the antenna signal to turn on the amp instead of the factory amp turn on signal
1999 Contour SVT
Moderated by  dnewma04_dup1
