Posts: 119 |
No hard feelings at all here. From what I have gathered so far alarm install all require the same thing(as far as connections). A good installer can make a cheap alarm work pretty good. But its only going to work as good as its features. Some things that take into account: sensitivity adjustment, sensor placements, alarm programming. Any info about code alarms that I mentioned before was from the installer I work with. He is very good and been doing it for 15 years or more. Maybe he is a little out of date but not by that much.
18" enkei cdr9 w/ kumho 225/40/18 5% limo all around alpine head unit jl xr series door speaks 2 jl w3 w/ppi 2600 and 1 farad cap b&m clear head lights dingless
Posts: 1,083 |
no worries boys, I just posted to show that they have "improved" their code grabbing technology.
this little guy :p would basically mean no harm no foul regarding this post.
you'll also notice I said I can only comment on this as this is the only one I have.
All in all, any alarm is better than no alarm.
PS. Code does OEM for General Motors, Ford, DaimlerChrysler, Mitsubishi, Subaru, Honda, Kia, Mazda, Toyota and Volkswagen
1998 SE ATX Dual exhaust Body conversion Nakamichi CD-40z HU Sound by Crystal Mobile Powered by a/d/s M860 AMP My Ride
Posts: 299 |
I have a commando alarm (501-s for $50 it can\'t be beat  ) (don't laugh, i'm serious) and it works pretty well. I bought it mainly for the keyless entry and trunk popper, but it works great as an alram. the brain is very small and fit nicely concealed on top and behind the fuse box. Its impossible to see, you can only fit your hand back there. It was very easy to intall (only 10 wires to splice, the whole thing took only 3 hours) I taped the alarm harness to the ignition harness, and the wires are all mixed up..its extremely hard to tell which wires go from the fuse box to the iginition and which to the alarm, the shock sensor is actualy surprisingly sensitive also...any alarm will work great, just do your research and ask questions. A lot of people are more than happy to show off what they know.
Silver 1998 Mystique LS (v6)...ATX  Removed Emblems, limo tint, painted calipers. Premier P630 HU with 4 Pioneer TS-A6895 Speakers with 10' Sony sub (yeah i know, i'm cheap) Commando 501-S Alarm
Posts: 515 |
Check out Directed Electronics . They make the Viper (I am happy with it) but also the types that wire into the stock system. Also, check out this sytem, DEI's Hornet System, connects to your present RKE and uses your existing remote... Good luck
"My Name is Richard. I am a Contouraholic." 1999 SE Sport Duratec ATX Spruce Green; Drop--In K&N Filter; VentShades; Fog Lamp Fix Mod & PIAA510s with Bumper Braces & Stock Type aiming screw mod; PIAA 9006 Super White Headlamps AIWA CDC-MP3 HU; WeatherTech Mats Viper 600ESP w/Remote entry
Posts: 1,444 |
wow. nothing about clifford? (even though they were bought by dei) i don't have an alarm yet but will likely get the clifford ag4.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 515 |
Originally posted by hmouta: wow. nothing about clifford? (even though they were bought by dei) i don't have an alarm yet but will likely get the clifford ag4. Clifford's are on the DEI site. DEI has 7 or 8 different systems.
Posts: 73 |
thanks for all the input guys  glad i could stir up some debate. these board can get pretty boring
Black 2000 SVT Contour #616 of 2150 SVT/SHO Society Member. I got stuff - tinted, brushed and thumpin'
Posts: 325 |
Apparently DEI scrapped all the clifford models except the high end G4, which they are fine tuning my rep was telling me.
1999 Silver Frost Contour SVT 2690 of 2760 Born 08/13/1999 Sony Mobile ES CDX-C90 Deck 6 1/2 Infinity Kappa Perfect mid & tweet set, 2 12" Infinity Kappa Perfects JBL P.600.1 for Bass, P.180.2 for front stage.
