Originally posted by livinsvt:
Don't mean to rain on your parade but code alarms are the worst. They don't use a rolling code, which means they all use the same frequency makin it easier for someone to unlock your car with a different device.
sure their fruit cake! If someone wants your gear, they'll grab it regardless. An alarm is only as good as it's install but the worst....wow, you must know your stuff to make that claim :p
SECURITY SYSTEM WITH OPTIONAL REMOTE CAR START
SYSTEM INCLUDE TWO REMOTE CONTROL AND
DNA MODULE CODE SHIFT PROTECTION hmmmmmm, i wonder what that could be!TWO 7 BUTTON LABELED TRANSMITTERS
8 ON-BOARD FUSES WITH 4 SELECTABLE POLARITIES
11 ON-BOARD RELAYS
STARTER DISABLE
KEYLESS ENTRY
RELAYS SELECTABLE DOOR LOCK OUTPUT
REMOTE SILENT OR AUDIBLE
ILLUMINATED KEYLESS ENTRY RELAY
ILLUMINATED ENTRY
ILLUMINATED EXIT
NOISE POLLUTION CONTROL
PASSIVE DOOR LOCK ACTIVATION
LONG TRUNK OPTION 0.5 OR 20 SECOND OUTPUT
FOUR AUXILIARY OUTPUT
AUTOMATIC OR REMOTE STARTER DISABLE
DEDICATED REMOTE CAR START OUTPUT
FACTORY ARM OUTPUT
FACTORY DISARM OUTPUT
LED/CHIRP/LIGHTS THEFT INDICATOR
EXTERNAL SENSOR OUTPUT
STANDARD 125 DB SIREN
PROGRESSIVE SOUND CAR FINDER
EXTENDED RANGE ANTENNA
FLASHING PARKING LIGHTS
EIGHT POSSIBLE REMOTE CONTROL
TWO CAR OPERATION CAPABILITY
REMOTE VALET MODE
HORN HONK OUTPUT
ON-BOARD IT-S SENSOR
REMOTE SENSOR OVERRIDE
TRIP MEMORY RECALL
LIGHT IMPACT WARNING
REMOTE ADJUSTABLE SENSOR
125 FT. RANGE
SUPER BRIGHT LED INDICATOR
LOST REMOTE DEACTIVATION
SECURE EMERGENCY OVERRIDE
HIBERNATION SLEEP MODE
ULTRA LOW CURRENT DRAW
