The one for the Contour's upstream sensors should be a square plug with 4 male pins on the oxygen sensor side.
The downstream sensors should be a round plug, with 4 male pins on the oxygen sensor side.
Make sure you're not accidentally looking at the downstream sensor connectors.
You want to replace the upstream sensor.
SMP has a catalog at
http://www.smpcorp.com -- check the part # there.
