Page 1 of 3 1 2 3
TonyD Offline OP
I bit more than I can chew with this thing. It measures 17"x14"x4" and about 25lbs. this thing is huge. How do i make a flase floor for the amp with plexi to show it off?
Rates at
  • 8 Channels x 60 watts
  • 6 Channels x 60 watts + 1 channel x 180 watts
  • 4 Channels x 60 watts + 2 channel x 180 watts
  • 2 Channels x 60 watts + 3 channel x 180 watts
  • 4 Channels x 180 watts
For more pictures check my sig below
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
Sound by Crystal Mobile
Powered by a/d/s M860 AMP
My Ride
JEEEEEEEEEZ 8 channel amp... wow.. im hopeing your doing some kind of competitions or have some sweet system.. that is overkill for just listening pleasure
Alcohol is my friend
Mongolian BBq S.H.
are you planning to mount it in the trunk? i'll be glad to give my 2 cents as soon as i can get a direct fix on what part of the car, and how you want to display it.
Give me more beer and CEG before i get depressed!
AIM/AOL: DBZ Jr
TonyD Offline OP
yes, i want to mount it in the trunk. no other place to put it-it is that big!
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
My Ride
2
2
Mount that bad boy in your box!
Do you plan on losing the spare? That's the only way your going to be able to mount it in the floor. Otherwise, maybe an amp rack mounted to the rear deck would work better?
2000 SE Sport V6
Deep Navy CC Metallic
My 2G Sport
Kai Offline
You can see the rear rack mounted amp that I have here:
http://kai_se.tripod.com/main.htm
smile
Kendall
'97 GL Zetec ATX
" Nippy "
TonyD Offline OP
spare tire is already gonzo!
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
My Ride
Try a similar set up to mine, but have amp on one side and sub on the other:
http://community.webshots.com/photo/32847417/31274771EtGxskywMv
Then build a cover to hide or conceal it. I'm in love with your amp selection! Aside from the usual qualities of a/d/s (strong, musical, transparent, efficient, accurate), it has major flexibility all in one chassis. Excellent choice! Had I not gone for the NAK's I'd have bought the a/d/s power!
MArk
TonyD Offline OP
Trapps
SWEET MOTHER!!!! Things that make you go VROOOOOOM!
I like your set up but i can't afford the room! This has been my biggest battle. I need all the trunk space i can get.
You can't go wrong with Naks either. Although, at $180 love my amp even more each time i look at it!
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
My Ride
180.00!!???!?!?!
How did you get it for 180.00?
I am overwhelmed with jealousy right now....I officially hate you Tony Danza!
I just lifted my hole floor up ~3" so my amp would sit flush with the floor. If you want to use plexiglass to cover the amp, just make you have adequate ventilation with a couple of fans. BTW, I lifted the floor by just making a frame that sat on the floor of the trunk and then made a new floor out of 2 layers of masenite.
Page 1 of 3 1 2 3
Moderated by  dnewma04_dup1
