Posts: 86 |
what are some suggestions for what to put in my doors?????
99'Contour SVT #1766 of 2760 stock-for now, mods in the making pionner deh-4400 cd/xm head unit pioneer 4x6 component plates(front) pioneer 3-way 6x9 (back) (2)8" Boston Accoustic Rally Series subwoofers Alpine 3527 amplifier MTX RT-XO1A electronic crossover
Posts: 1,251 |
Posts: 4,585 |
How much do you want to spend and how much work do you want to do?
Posts: 86 |
good clear sound, my hu is 50x4, i'm gonna stick with that for now...so i looking for a range of 35 watts to 100 watts rms.....i would prefer to avoid components, unless the price is really good....i have 4"x6" component plates by pioneer, do you guys think these will fit in my doors....i'd like to use them because of the high-pass x-overs that come with them....and maybe just put some 6"x8" in the rear doors....any other suggestions????thanks guys
Posts: 1,032 |
FYI, your HU puts out about 20x4 RMS. That 50x4 is a peak measurement which is for the most part a useless marketing gimmick.
I wouldn't use the 4x6 plates if you plan on a system without a dedicated sub.
1999 SVT #900/2760 Born on 1-20-99 Silver Frost/Midnight Blue A few aesthetic and audio mods
Posts: 1,375 |
How hard is it to install the pioneer 6X9's in the front and rear? IIRC the model # was TS-A6995 Anyone have these or recommend them?
99 SVT Tropic Green #151 of 503/ 2760 total Born on 10/07/98 Adopted 7/15/00 LETS GO RANGERS (looking good this year)
Posts: 263 |
pioneers are pretty decent, i put 6x9 in my front and rear, sound great. all you need is a drill and some screws.. you need to make new holes.. but thats about it.. i have cerwin vega HED 1693. and some subs..
Alcohol is my friend Mongolian BBq S.H.
Posts: 730 |
Originally posted by slim shady: How hard is it to install the pioneer 6X9's in the front and rear?
 I have the premiere version of the Pioneer 3-ways (TS-906), and they just took new holes in the front and new holes + a little grinding in the rear. But be careful with those 4-ways. My friend got the premiere version of those for his car, and they are considerably deeper and bigger than mine, because of the larger magnet. You'd probably have to use a spacer to clear the window.
Kendall '97 GL Zetec ATX " Nippy "
Posts: 918 |
How about buying/making an adapter for 5 1/4 or 6 1/2" speakers? That would give you a lot of choices. Speaker adapter for Contour
************************* 2000 SE Sport V6 Deep Navy CC Metallic My 2G Sport *************************
Posts: 86 |
[QUOTE]Originally posted by SVT Colin: [QB]FYI, your HU puts out about 20x4 RMS. That 50x4 is a peak measurement which is for the most part a useless marketing gimmick.
thanks for the heads up, but it's 22watts rms...it's usually half or a little less than half of the peak power...but thanks anyways...do you think i'd need to make a mount of some sort...since i'm putting 4"x6" plates in a 6" x 8" opening???? i gues i'm just going to have to rip the door panel off and check for myself.....someone said that they put 6"x9" in the doors....how long did it take to modify the opening? thanks guys
