Posts: 1,032 |
If you can hear a different between 20w and 22w, then your ears should be classified as scientific instruments. :p
You'll need to make a baffle using some 1/2" plywood or something. Just pop out one of the 6x8s and trace its outline onto the plywood. Cut it out and also cut out a corresponding mounting hole for the 4x6s. Presto! You've got baffles!
Different 6x9s take different modifications to be used in the 6x8 openings in Contiques. It depends on the mounting depth and speaker basket design. Some require cutting/grinding metal, some only require drilling new screw holes, and some won't fit at all. Try a search on 6x9s and see which models fit with the least modification.
1999 SVT #900/2760 Born on 1-20-99 Silver Frost/Midnight Blue A few aesthetic and audio mods
Posts: 86 |
hey i have dog ears when it comes to music.....  ...i also have some old pioneer 6x9 3-ways,but one of the speakers has a hole in it...thought i try some silicon for a temporary fix until i get new ones.....i can't use my sub until i replace these speakers...the distortion is killing me.....ok so i gotta make a baffle for the 4x6's and maybe cut some of the rear door for the 6x9's.....thanks for your help Colin.
99'Contour SVT #1766 of 2760 stock-for now, mods in the making pionner deh-4400 cd/xm head unit pioneer 4x6 component plates(front) pioneer 3-way 6x9 (back) (2)8" Boston Accoustic Rally Series subwoofers Alpine 3527 amplifier MTX RT-XO1A electronic crossover
Posts: 1,032 |
Sure, no problem. What's that? I'm typing too loud?
Posts: 86 |
i should have pictures posted tomorrow night, of my enclosure....i will have a post regarding it, soif you see it check it out....later
Posts: 1,444 |
those scosche adapters are for 5 1/4 only. the metra adapters are for up to 6 1/2.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 86 |
uhhhh how do you guys get the pics in your replies????? i have pics but haven't a clue on how to show them to you guys???? can you help me w/ dat????? :rolleyes:
Posts: 1,251 |
Hit "Reply with Quote" (looks like two little quotation marks) and you will see the UBB code. Try doing it with this post... or you can just click the "Image" button below the text window when you're making a post and just type in the URL of the photo. Obviously, you'll have to load the picture onto a server somewhere first.
Posts: 86 |
thanks guys...i try it....if i can figure it out..... how can i post them on a server?????????? my work network has a server...would that work???????????
